Hi Guys.
Im selling an air to air cooler. Compact but large.
Details are as follows
Overall length 735mm
520LengthX160HeightX127Thick dual tube&fin core
Low pressure drop
Sand cast & polished end tanks
3inch centrally located & angled back pipes
Pressure tested for leaks
2X3" silicon hoses & pro series clamps(X4)
3 welded on bosses top/bottom with 6 steel mounting brackets
Great for low front ends
Everything that you need
275 ONO
https://www.sau.com.au/forums/topic/290682-intercooler-air-to-air/
About 30 degrees angled back each side. This is a universal Cooler and is low pressure drop
and good value for money. Sorry I am unable to post up pics due to issues @moment but rest assured
that this is a perfect item & there is no monkey-business
Thanks guys
Brand new intercooler in box & a generous size. Somebody buy this & fit it to their car. The only reason that I didn't fit it is that I didn't want to spend the extra $ getting the front bar trimmed back to fit it.
This is blasphemy a perfectly good cooler sitting around doing nothing
:P
Good volume and cheap. Flows well without too much pressure drop as you get with oversize coolers.
Why have a drag one when you dont have a drag car. Response is where its at :happy:
uumm, will u separate the core? im looking for r34 gtt, so piping wont match at all.
and able to pick up w/o any hassle.
let me know.
cheers.
Seperate the core ;) are you serious man
Please send me a p.m 4 quik response
Thank you
  • 1 month later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
