I already have a wolf3d V4 in my r32 with a 25det + gcg highflow. Now what is going to be easier to tune and give the better tune overall?
I realise buying a 20det ecu and nistune plus starting the tune from scratch is probably going to creep towards $1000 but I can get at least $500 for the wolf ecu. If I stick with the wolf ecu I will only need 2-3 hours dyno time ($300 ish) to get the tune tidied up (already has been tuned for 220kw run in tune) but it is not going to be as fuel efficient or idle as well, the reason being the stock ecu has fully sequential injection where as the wolf has to run batch mode (fires 2 injectors at once).
What would you guys do for a car in the 240-260kw range that is daily driven? Not to mention I have to go through regency (defect inspection) in the near future so I will need a stock ecu, the 20det ecu with a nistune will help me out here.
Edited by Rolls
https://www.sau.com.au/forums/topic/290801-wolf3d-v4-or-nistune-r32-with-25det/
well if you have to go through the defect inspection thing, then id say the nistune, i have one in mine, loving it.
Yeah that's what I'm thinking, the wolf doesn't offer me any features that make the lack of sequential injection worth it and the fact it is defectable.
You might be better of running a z32 ecu plus nistune so you can take advantage of vvt.
My only gripe with the nistune is that you have no knock lite.
Yeah a knock light is a cool feature. You know whats even cooler?? Auto retard when knock is detected i'd think id rather save my engine than blow it up and know the knock count.
Edited by Crans
Hmm I've dropped the car off at boostworx. Maybe I will go pick it up (they haven't done anything yet) and do some more research and be 100% about what I should be tuning it with and who I should get to do it.
Really is a headf**k finding a good tuner and knowing what ECU to use. Really is hard to sort the good tuners from the bad tuners. Everyone has a different story about what ECU to use as well, like I'm talking 100% completely opposite opinions from well respected people.
Being as I have to go through regency and need the stock ECU I think the nistune really can't be that bad an option to go with though.
Edited by Rolls
uhh i dont remember saying i would rather a knocklite INSTEAD of nistune pulling a bit of timing out, Jus saying it's a handy thing to have diagnosing a problem that you dont know exists is kinda hard.
    • Yeah that's true, but idk. Only a 6 month lifespan seems a little short. Oh also, is there a preferred way to send images? Like any sites? I'm used to just being able to upload them lol
    • Hey, like MBS206 mentioned; I dropped off my short block and rotating assembly Monday. With a quick verification, he believes he can clear it up with just a hone and new rings but he will confirm once the rotating assembly is out. If I were you, I would either go stroker or just replace the block if it does need to be bored over to next size. Block is cheaper then forged pistons.
    • live in the UK, and London has introduced a Low Emission Zone (LEZ) that requires individuals to pay £13 if their car doesn’t meet the required emissions standards.   The standard specifies that NOx emissions must be less than 0.08 g/km (i.e., the vehicle must meet Euro 4 standards or better, which generally results in NOx levels of around 0.08 grams per kilometer).   I reached out to Nissan UK, and they advised me to contact Nissan Japan directly. Does anyone have contact details for Nissan Japan or any certifications of conformity that show the emission details or NOx levels for the RB25DET engine?   Any guidance would be greatly appreciated.
    • these guys recommended to me and supplied custom 4 inch mufflers, couldn't be happier. They will spec a muffler to your preferred level of sound and know RB's well.  https://spmufflers.com.au/
    • Yeah this used to happen to me every year and a quick call would at least raise the agreed value back up / reduce the premium, but usually both.    That said for the first time on the renewal this year our agreed values went up or stayed the same over the fleet and the premium came down so that was a nice surprise.
