OK have booked us a hotel in Shepp for the upcoming DECA.
When: Fri 6 & Sat 7 November
Where: Tirana Motor Inn
Address: 33 -37 Wyndham St, Shepparton
Website: (if you wanna have a look) http://www.tiranamotorinn.websyte.com.au/
Cost: $50 per person per night
If you would like a room, please let me know as soon as possible, they will want to release to the public whatever rooms we are not using in a couple of weeks.
I need to know:
* nights staying
* how many people
* what bed configurations you need (ie twin, double etc)
If you are coming by yourself, that's fine, just let me know and I will team you up with somebody else to share a room with.
Dinner is booked at 7pm at the old Taco Baz establishment - now called Not Just Mexican!!
Let me know here, by email, by PM or by phone.
The sooner you tell me, the easier you make it for me.
  • Replies 71
People staying:
Fri & Sat
Bec
Ryan
Mick
Tim
Scotsman
Luke + 1 and Luke's friend +1 (2 rooms)
Kieran Robinson, Chris McColgan, Gary Swift & Colin Clark (one room)
Wayne & Leon
Shane
Justine & Newton
Juliette
Tony
NSW Steve-o and Nick
Tim, Campbell, Mat, Russ and Dean (one room)
Al
Che, Ben and Jim (one room)
Sat only
Ash (ashneel) + 4 mates (split in 2 rooms)
Fri only
Tom G
People staying:
Fri & Sat
Bec
Ryan
Mick
Tim
Kieran Robinson
Chris McColgan
Gary Swift
Colin Clark
Chuck us four in the same room if you can please, might be difficult considering none of us want to sleep in the same bed.
Definitely doing skittle bombs! Its the least we can do considering all the effort you go to for us.
Put me down for Friday and Saturday. I'll go for a room by myself this time if that's okay? Obviously if that's an extra cost no problems :(
if you have too much money you can give it to me!...
You do realise how much my car cost me to fix after last DECA and the fact I only got it back last weekend? I don't have too much money. I'll just sleep better by myself :)
AFAIK We will not be able to make dinner and wont need accomodation. We have tickets to see Strassmans Ted E Bears Farewell tour that night. Will let you know if it changes.
Guest
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
