Hi
Anyone free this saturday to spend a couple of hrs with me. I may be coming over from perth to look at buying this M35.
http://www.sinergymotorsports.com.au/thumb...s.php?album=390
I'd need a lift from the airport to sinergy motorsports and back.. I will pay for petrol and lunch!
cheers
Wil
https://www.sau.com.au/forums/topic/290850-adelaide-stagea-potential-buyer/
I wouldnt mind a 260RS! but I gotta get an auto cos wife needs to be able to drive it...
I havent booked the flight yet, car is being inspected by Motacheck today, dealer recommended them - I hope they arent 'affiliated'.
There's usually a flight that arrives around 930am or the next one is just after mid-day, will let yas know cheers!
PM Sent with the details Will (didn't see your thread until now. Sorry)
I have been told that Synergy to actually have pretty good stock.
That Axis kit is not an option from factory for an ARX (as you will see in the PM).
It has been available for a considerable amount time (over a year I think) and $27k is too high IMO.
If I recall correctly, it has Tein suspension, but other than that and the Axis kit, it looks pretty stock to me... although I am confused... Where did the aftermarket screen go?
It was in the rear interior pic, but not in the drivers seat pic.
hmmm.
I was wondering exactly the same...
Looked like one of the "much more useful than OEM" Panasonic units, like mine.
hmmm.
Yep looks like the bose system. Doesn't the screen pop down into the dash?
It has definitely been lowered. The wheels may fill the guards but whats their excuse for the low (ie. non-ARX) ride height?
74000kms is pretty normal. Most freshly imported M35's I've seen are in the 60-80K kms ballpark.
25K seems a little high but then I'm not sure what AR-X's go for...they're definitely a higher spec than the RS and a notch up from the RX too if I remember correctly.
Got them down to 25k, still a premium...
It's advertised as Bose sound system...
Sales dude reckons its standard suspension but because the wheels on arx are higher profile it fills the guards better. :O
Does he realise that while the ARX has 18's as opposed to the RS's 17's, the ARX is also 40mm higher than an RS, RX or Axis?
Definitely check out if it actually is the Bose system. Bose and the standard integrated system look almost identical
Edited by iamhe77
?? I thought the standard integrated system IS Bose? There's another AR-X on carsales that has the same one.
Yeah they've got a silver axis there grade 4C with auction papers. K's are too high for my liking though.
I'm not too keen on the suspension being so low, i've heard teins can be quite stiff.
There are three audio systems.
RS gets the Clarion single DIN unit (which allows for the 3 gauge unit or storage compartment)
The RX and ARX all have the integrated dash, but it can be either the Bose option or standard unit (clarion maybe?)
I believe that the Axis models come standard with Bose... but I may be mistaken.
Edited by iamhe77
Hey Guys
thanks for all the volunteers to help. The car is in some sort of warehouse.
I paid for an inspection done by Motacheck yesterday.
The car isnt quite what i'm looking for so I wont go to adelaide this weekend.
Main thing is the suspension is so low it bottoms out over smallish bumps. Rear is unstable when driving... inside tyre wear on front tyres... in my opinion could have been a car setup for drift... could explain the replaced front bumper and rear tyres had much less tread left than fronts. Everything else about the car is good though I am a bit fussy.
Today I'm bidding on a grade 4.5 ARX with 28,000ks on it!
cheers
Wil
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
    • Yeah, really happy with how it all turned out As for aftermarket lip, nah, I'm not really a fan for practically reasons on a street car that gets driven everywhere  I did have the full lower kit on my 2015 STI, but found the front lip scrapped alot, even at stock 4x4ish ride height As the NC sits now, with the lowest point of the car at 110mm, so just legal, some steep driveways and steep speed humps will still "just" scrap those little plastic OEM air dam thingies on the undertray just before the front wheels
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
