Hey guys
dropped my car on sunday morning to get the FMIC kit fitted in.
Heres some progress atm
Basicly the kit is a full custom job that'll be a production version later on
we have made this kit so it needs no cutting and in the front bar and the reo bar
also used a thinner fan for the a/c side.
pics will show much more.
apparently 2 versions will be available
premeium kit and the non premeium kit
price will be 500-700 depending on the kit
here are some pics now
Edited by [[d a n n y]]
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/
  • Replies 160
Looks very pretty Danny.
So is that a 600x300x76 core?
hmm, would like a larger thero fan than that, how thick is the fan you used?
Is the Premium using their GT tube and fin core and the non-Premium using their Bar and Plate core?
noice!
There's a bit more room in there compared with an s2 or s1
Is that 100mm core?
There is only that much room because the OE thero fan has been replaced.
No chance of a core that size otherwise.
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/#findComment-4865941
wouldnt the premium have the bar and plate??
Nah. 'tis all in the design!
Have a look at the HDi website and compare the GT core with the Monster Bar & Plate core.
I would imagine that these are the two cores that are in the premium and non-premium kits.
If you could not be stuffed surfing their site, the attachment below is a screen dump from their site... check the pressure loss comparison.
Edited by iamhe77
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/#findComment-4866021
hmmmm...... definitely the next on the list for me thing in a month or so....after I fix the small PB problem that is :mrt:
Just got to figure out where to put the gearbox cooler though. Danny we need to catch up again so I can do some measurements.
P.S. As Dale said "Thanks for all the help spending our money".
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/#findComment-4868077
Yeah right, there are s2 m35's? :mrt:
im not sure if that was sarcasm, but yes there are S2 M35s! they are a PM35 whereas our current M35s are an NM35, but the N means 4WD.
no VQ25DET was available as it wouldnt pass emissions. Right now there are people attempting compliance for them.
And yes, they are different, slightly, like the subtle differences between an S1 and S2 C34
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/#findComment-4868090
Not slightly enough as far as I am concerned.
Edited by iamhe77
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/#findComment-4868126
But you have sorted it out now?
No. Bonnet need modification.... and I need a grill (Dolphin one is $400!!!).
Looking like a more expensive conversion than I estimated :mrt:
Have a couple of other purchases that require attention before the front (including this HDi kit, methinks :) ), but will have pics when I do it.
https://www.sau.com.au/forums/topic/290851-hdi-fmic-kit/#findComment-4868136
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
