  • Replies 160
  • 6 months later...
wonders if its the newer kit.. my friend complained his gt hdi came with alloy coated tin piping instead of proper ally a few years back. and seems to think the quality has improved overall with the bar and fin.
i paid $899 plus $35 in shipping so $934 to my door.
slimline fan arrived today hoping my gt2 goes on as easy as others! - and will i have to relocate the trans cooler?
Well i thought id pull my finger out of my arse today and get this intercooler on now that the fan has arrived..
it went on suprisingly easy and had it done in 2 hours.
the hardest part was feeding the plastic pins through the condensor and radiator to pin the new slim line condensor fan without taking the radiator off.
goes better also :banana:
did mine as well last week. kind of eager took me about two-three hours also. the bent brackets in the kit were good to hold the new thermo fan in. i didnt want to poke through the radiator core as if youve seen how thin the thing is, and it for some stupid reason it would leak, it would be like trying to find a needle in a hay stack.
some of the picks are on my profile. i was really happy with it.
worth the $800 :D
Edited by AaronNM35
worth the $800 :banana:
definately worth the money.. wasnt worried about the fins in the radiator as its more than tough enough to hold the weight with the condensor
another Black AR-X aye!!! :D
Just abit of advice knowing someone else who did this.
those Zip ties expand under heat, his condenser fell out, Could be a different brand of ties(quality +/-) but I didnt wanna take the chance. I'de keep an eye on it..
Edited by AaronNM35
dunno how his condensor fell out .. when its sitting under and behind the radiator support bracket on two sides and then the radiator on the other side and cant move. :P
the fan weighs about 200grams its pretty light. and the thick fins support it right through without it going near tube walls .. i wouldnt have done it if i didnt think it would hold.. but ill check back on it periodically ..maybe he meant the condenser fan fell off if the plastic pins melted?
that seems like a more likely scenario.. ill keep an eye on it and employ the angled brackets (if theyll reach) if it goes pear shaped
Edited by PetroDola
dont really know what happened with it, it wasnt a stagea it was a wrx..just after seeing it i didnt wanna take the chance.
  • 3 weeks later...
What's the performance gain from fitting one of these? Well worth the $$$?
As we run fairly high boost, yes it will make a fair difference, especially on hotter days. Worth the cash? I wouldnt bother until the exhaust and highflow is done.
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
    • SO whats the deal with this issue? I've read a heap of posts from the infinity owners in the US having full engine swaps done under warranty. Most claims are done on earlier cars than 2019 but I'm sure I've come across claims of 2020 models also having this issue. I like the 400r and Q50Red/S but can't fathom dumping close to 50k on a car with terminal issues!!!
    • The above video is working normally. That is, that's how the right hand indicator should cancel when rotating the wheel left.
