  • Replies 306
Posted Images
Proudly Presents:
Micolour SAU-Vic DECA Motorkhana Round 4
When : Saturday 7th November, 2009
Where : DECA - Shepparton, 145 Wanganui Road, Shepparton, VIC 3630
Cost : $80
Max Entries : 50 + Reserves
-= PLEASE NOTE =-
The insurer of the event (AASA) has issued supplimentary regulations that require all entrants to wear helmets during all competition. This includes the skidpan and all battles.
This also impacts passengers, as they must also now wear a helmet prior to entering a competition vehicle.
A fire extinguisher is required by all entrants. This is for your own safety.
Please re-read the supplimentary regulations before entering the event.
Entry Form & Supp. Regs. : Click Here - TO GET ONTO THE LIST WE NEED YOUR ENTRY FORM. NO FORM NO LIST
Event Schedule: Not yet available
Results: Not yet available
Anyone paying by cheque MUST make the cheque out to Skylines Australia Victoria. Cheques made out to anything else WILL BE REJECTED.
Please support our sponsors : Micolour - Custom Refinishing, 7 Dissik St Cheltenham 3192, Ph: (03) 9555 8011.
Hi guys, Juliette from the forums told me to check this event out so ive joined up on the forums.
I'm pretty keen to do a motorkhana, it sounds like it would be a lot of fun (from the name anyway!). However, ive never done one before.. Can anyone give me a quick rundown on it, like the sorts of things they have you doing, whats involved, etc.
Also, it has a clause saying that the car must be 'roadworthy'.. I have a dedicated track car i plan to bring, which passes scrutineering for the sprints at Winton, but im sure wouldnt be considered as roadworthy by VICRoads :) . Can anyone clear up what the entry means by the term 'roadworthy' in this instance?
Thanks!!!!
Hayley
As long as it isnt a buck of shit datsun it should be fine.
The sup regs outlines everything anyway, i think, Crossy wanna clarify this?
I wont be coming to this one, got something up in Syd that weekend.
Mardi Gras? :)
Thanks!!!!
Hayley
No leaks, no belts(tyres), yes belts(or harness), secure panels, fire extinguisher... if its race worthy, it should be fine. This is what i gathered from the cars i saw there, the scrutineer should post at some point
Roadworthy mostly refers to your car having tread on the tyres and being safely (somewhat subjective) drivable...keep in mind that if your track car is running full slicks then you'll be penalised with timing.
The above is correct.
also:
- No loose items in the car. this includes glovebox and boot. also take out drivers foot mat.
- Battery secured properly. no cable ties.
- CHECK YOUR WHEEL NUTS ARE TIGHT
- Fire extinguisher is to be BOLTED in. not screwed or cable tied.
- Helmet must have adr sticker on it.
Fantastic thanks, i get it now!! OOO really wanna go!!
One more question though, maybe im too blind to see it, but do you have to be part of a club (someone mentioned i may have to)? Im a forum member on the WRX forums, and now i have signed up here, however i am not an official paid member of any club. If so, I might have to look into getting a membership somewhere
Yeah gotta be a financial member of a car club.
also:
Unfortunatly I am out for this one... couple of the other guys will be taking over the Scruitineering.
I really must stress Ryans 4th point there...
This is the worst prepared item by the majority of entrants at every DECA...
If you are going to enter... please check you fire extinguisher is BOLTED FIRMLY to your car....
If you are not sure... mount it in and then grab it and shake it vigirously... if it doesn't move it all you have done a good job.
Just imagine to if you are in some sort of accident and your flimsy bracket or cable ties let go....
helmet or not... a fire extinguisher is gonna leave a big hole through your head!
Apart from the obvious persoanl ramifications - i.e. death....
We simply just can't be bothered with the paper work, and DECA management don't appreciate blood on their skid pan... (Its a pain to clean off) :(:P:P
/rant....
Hope you all have a great time...
and hope to be back out there soon... (with an extra 2 cylinders :cool::down::/ )
Guest
    • I mean it's probably likely that people overestimate their skills in dialling in a setup and noticing the changes. I had SK shocks and springs, and added heavier springs and got them revalved by Sydney Shocks to suit based upon what I told them I wanted the car to handle like. I got back a completely different feeling set of shocks, which probably (?) feel great on track but holy hell are they rough on tram tracks and the like. The shock dyno actually looks pretty similar to Shockworks (from what I can surmise from a screenshot of a youtube video - and my dyno printout...) Truth be told I doubt I'd be any faster or slower with either setup, or camber/castor combination. I also had whiteline eccentric castor bushes up front of my R34. I removed them and put in poly non-adjustable ones to soothe my OCD (nobody ever set the castor the same side to side, and it'd be near impossible to do) and be happy the wheel is centered in the well now for clearance reasons. Yes I wanted it to move 1mm 'back' :p I've effectively set my castor back to stock, negating all the benefits of that which is supposedly massive. I've probably also altered toe and camber in a negative (detrimental) way. I can't tell any difference steering the car.
    • You reckon? I have to disagree. Notwithstanding that at some point we may all be forced to do this to our cars if we want to keep driving them, there is absolutely nothing about an electric-converted-previously-IC-car that is ever good. EVs that are built by OEMs on platforms that were originally IC already suck, let alone the shitty outcomes that result from doing it as a retro to something that was actually built as an IC car. This is because the platform really needs to be designed to house the battery in a useful place (ie, down as low as possible) and the motors are properly located relative to the wheels that they have to drive. Converted platforms already suck at this. But when you try to shove sufficient battery capacity into a previously IC car, you can't put it down on/in the floor, because that space doesn't exist. You can't find enough space where the fuel tank used to be (if it is an inboard fuel tank) and you don't want to hang it out behind the rear axle line if you had a rear fuel tank. And there's not enough space in the tunnel if you still want to use it for anything remotely like what it was originally used for. The engine bay is too big for a motor, and you'd really prefer that the motor for the rear wheels wasn't in the front engine bay anyway. And there's not enough room where the diff was for a proper man-sized E motor. And then.... there is the complete lack of soul and emotion that is provided by EVs. There are some cracking restomods out there. Like the Alfaholics GTA thingo. But it is petrol powered. Look at the alternative EV version of a GTA restomod by Totem. it is jaw droppingly beautiful. But by all reports is is objectively awful to drive, despite having 600 HP or something, simply because there is nothing there. It sounds like a sewing machine or a leaf blower. It should scream and wail and make the hairs on your neck stand up. Oh, and it's 1500 bloody kg in a car that was <900kg when new. GTRs are heavy enough as it is without pushing them up to 2tonnes worth of pork.
    • https://www.dezeen.com/2025/01/06/nissan-electric-r32-skyline-gt-r-godzilla-sports-car/   I reckon this is pretty cool. Lots of other Resto mods have turned to ev power.
    • hahaha @joshuaho96 the most action it gets is when I have to drive from West to SE VIC to meet the fam. Even then, it;s on highway cruising speeds
    • don't know anyone in this thread, but i just found it, read the entire thing in a few hours, realized greg is still posting progress, and just have to say, this is awesome. it looks awesome. 100% right about the Uras kit making it a pain to get on hoists...have the same kit on my 34 and it takes six 2x4s and race ramps to do it without taking parts off. this reminds me exactly of this thread. https://grassrootsmotorsports.com/forum/build-projects-and-project-cars/r63-amg-the-unicorn-of-my-destruction/110824/page8/
