When its been sitting over night and its a cold morning or its been sitting all day at work and come out after and its a cold day some times when I start it it runs rough and idles low were talking 250 to 500 rpm, it then dies. If I re start it it then idles at normal cold start 1100 and everythings fine.... If while its idling rough and before I dies I give it a small rev to bring it up past 1500 rpm then let of the throttle it then goes into cold start and doesn't die and runs fine..... Anyone got any ideas? Apart from this it runs sweet no missing or anything...
https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/
there will not be any definite answer due to the fack that it could be a multitude of things...
fuel filter clogged? spark plugs? how does the car run (both of you) when its normal?
my 33 has been doing this in freezing cold weather since the day it landed here from Japan. I thought it was normal 25det behaviour. Only on freezing cold starts though - if the temperature (weather) is say, over 16degrees, it cranks over and purrs away first time without any throttle
I live at the top of the Blue Mountains in NSW, and we've had some very cold winter days. No such troubles with my R33 GTS-T S1, so, no, it's not standard behaviour. (Toyko's pretty cold too, isn't it?)
