Jarrod19831 Posted October 6, 2009 Share Posted October 6, 2009 When its been sitting over night and its a cold morning or its been sitting all day at work and come out after and its a cold day some times when I start it it runs rough and idles low were talking 250 to 500 rpm, it then dies. If I re start it it then idles at normal cold start 1100 and everythings fine.... If while its idling rough and before I dies I give it a small rev to bring it up past 1500 rpm then let of the throttle it then goes into cold start and doesn't die and runs fine..... Anyone got any ideas? Apart from this it runs sweet no missing or anything... Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/ Share on other sites More sharing options...
AJ2235 Posted October 6, 2009 Share Posted October 6, 2009 This post isn't much help what so ever. but im having the same problem with mine. ive done a bit of searching on a couple posts but have never read a definite answer. so i hope someone gives one Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/#findComment-4865510 Share on other sites More sharing options...
DC33VN Posted October 6, 2009 Share Posted October 6, 2009 you should add what mods your running etc, might make it abit easier Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/#findComment-4865528 Share on other sites More sharing options...
.:: GimpS-R34 ::. Posted October 6, 2009 Share Posted October 6, 2009 there will not be any definite answer due to the fack that it could be a multitude of things... fuel filter clogged? spark plugs? how does the car run (both of you) when its normal? Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/#findComment-4865794 Share on other sites More sharing options...
Luciano Posted October 7, 2009 Share Posted October 7, 2009 When its been sitting over night and its a cold morning or its been sitting all day at work and come out after and its a cold day some times when I start it it runs rough and idles low were talking 250 to 500 rpm, it then dies. If I re start it it then idles at normal cold start 1100 and everythings fine.... If while its idling rough and before I dies I give it a small rev to bring it up past 1500 rpm then let of the throttle it then goes into cold start and doesn't die and runs fine..... Anyone got any ideas? Apart from this it runs sweet no missing or anything... my 33 has been doing this in freezing cold weather since the day it landed here from Japan. I thought it was normal 25det behaviour. Only on freezing cold starts though - if the temperature (weather) is say, over 16degrees, it cranks over and purrs away first time without any throttle Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/#findComment-4867023 Share on other sites More sharing options...
Jarrod19831 Posted October 7, 2009 Author Share Posted October 7, 2009 My car only has pod filter, that is it.... the rest is stock if that helps you at all Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/#findComment-4867084 Share on other sites More sharing options...
CatsEyes Posted October 7, 2009 Share Posted October 7, 2009 my 33 has been doing this in freezing cold weather since the day it landed here from Japan. I thought it was normal 25det behaviour. Only on freezing cold starts though - if the temperature (weather) is say, over 16degrees, it cranks over and purrs away first time without any throttle I live at the top of the Blue Mountains in NSW, and we've had some very cold winter days. No such troubles with my R33 GTS-T S1, so, no, it's not standard behaviour. (Toyko's pretty cold too, isn't it?) Link to comment https://www.sau.com.au/forums/topic/290896-need-help-with-skyline-r33-gtst/#findComment-4867720 Share on other sites More sharing options...
