Hey guys just picked up a v35 very very cheap as its had a front end hit. I really need to track down a
left hand gard
left head light
new front bar
an posible the left suspension set up.
can anyone point me in the right direction.
i am located in brisnbane.....
also thinking of putting a kit on it.
Steve
https://www.sau.com.au/forums/topic/290900-need-v35-parts/
Yer spoke to them 2day. still waiting for them to get back to me............
Well option 1 was no help at all........still waiting for them to get back to me......after calling them 3 times, an getting the run around.
Can anyone else point me in the right direction of local parts or put me intouch with someone who i may be able to import parts myself??????
https://www.sau.com.au/forums/topic/290900-need-v35-parts/#findComment-4869737
ok. tell me EXACTLY what you need. reason I sent you to option in the first place is the fellow that supplies the ENTIRE east coast of Oz with jap parts operates from there. he's in osaka now getting cars/bits and I can contact him if required.
if you are price shopping for bits - dont bother me. if you have $$ and want bits then I can help. blunt call I know but this is the way he operates and when talking to him I need money in hand, not I will pay for these later and he gets stuck with things.
https://www.sau.com.au/forums/topic/290900-need-v35-parts/#findComment-4869762
Mate I have the cash. I just need to find the parts........ I can get them all new fron nissan, but when your paying $1300 for one head light its time to start shopping around. I'm in talks with a guy on ebay about all the parts i need atm...but if that falls through I'm sure i will be in contact.
https://www.sau.com.au/forums/topic/290900-need-v35-parts/#findComment-4879956
Just be wary of the ebay head lights. The US is diff to the JAP(what we need) version. Beams will face onto incoming traffic(not what we want) due to them being LHD.
Yer i know this but i'll will find away to ajust or if be replace the lense cone inside them as ther is not way in hell I'm paying $1300 for one head light. got a pair off ebay for $500
https://www.sau.com.au/forums/topic/290900-need-v35-parts/#findComment-4880470
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
    • That cannot have been a fun set of drilling. The stock "baffle" looks identical to rb26, I just cut fuel cell foam to fit the full length under the baffle.
    • I understand your sarcastic exasperation. But to be fair - the baffles do indeed fit OEM cam covers. They did omit to say that you need to do a bunch of stuff. But they do fit them.
