Hey all,
I am new to this forum as I have just bought a skyline after being a rotor boy for the past 5 years.
I have purchased a r34 gtt manual jap import. It seems to make a noise when the car starts up... but then stops after about 5 seconds.
The noise sounds like the hood is open and the metal stand is making the noise... if that makes sense.??
I have seen that ppl are using wd40 and replacing the belts etc... would this just be a belt related problem??
cheers,
Nick
https://www.sau.com.au/forums/topic/290919-squeaky-noise-in-r34-gtt/
What kind of noise is it?
Is it a squeal?
Is it a clatter?
Does it not happen when the car has been warmed up?
Without knowing more info, it might just be a belt. In that case, you can spray just a little WD40 on one belt and see if it stops. Stop the engine > start it again > see if it's silent. The WD40 is just a temp measure > check and replace the belt if necessary (if it's cracked, frayed or not sitting flush in it's pulleys.
If it's a clatter, you can get a 30cm wooden dowel and put one end on parts of the engine (with the other at your ear). Valve lifters?
Congrats on your purchase. How long ago did you take ownership? Was it a dealership? If it was & it's recent, could they look at it for you?
Hey its a squeel... and it only come on when i start the engine for 3 secons or so...
I believe it is a belt related problem.. mayb loose or old? but im worried because it goes away and doesnt come back until i start it again..
(I guess thats a good thing :mrt: lol...)
Generally only happens when car engine is alwready warm... ??
Hey.. nah its not an armarold problem cos he didnt shine it up or anything...
One of the belts seems loose.. possibly the timing belt? the top one of the r34 ... ?
A mate of mine said it could be a water pump bearing... ? any help guys.. it only stays on for a small time then goes until i start again..
seems like when i start it up the volt meter Fluctuates with the noise then stays stable... could this imply that the alternator belt could be loose??
help plz. :P
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
