Just cars gave me agreed value on my series one 33, from what i've seen a clean sub 100,000km series1 33 can range from 15k to 22k I paid 15 for mine and insured it for 18. :headspin:
I insured mine for $24500 agreed value (modified S1 R33). I expect this to drop considerably next year. One of the reasons why I'm thinking of getting a tracking device and buggering this whole insurance thing off.
I think the prices will rise slightly, esp as the new RAWS scheme is pretty expensive, and only stock cars can be complied. Also, alot fewer cars are being sold now, as not too many have been complied under the new scheme.
If you are having probs with the insurance company, just send in a copy of a few adds from the newspapers, or something like HPI wich have a few car trader adds.
anyone noticed the number of cheap R32 GTR's??
From Prestige...
Why is that...??
They are GTRs as you can see the RB26DETT engines and badging etc etc
They are here inc on road costs from around 20k...
What the??
Why....?
Anyone help? Because im tempted to get one now... instead of a R33 GTS-t for around the same price.. :headspin:
Most of them are the early 1989 R32 GT-R that can be imported under 15yo rule from around mid next year 2004. they are cheaper as only need engineer paper. But I reckon a later 94 R32 GT-R V-Spec II would still be pricey.
Nothing wrong with the old ones as long as they are original, never been overly modified then reliability shouldn't be an issue. Otherwise, could be a time bomb and better set aside a few thousands for engine rebuild just in case.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
