Hey all
Up for sale is my 96 R33 Skyline. Its a manual Series 2 with 116,000klms that ive owned for the past 3 years. I'm selling this because i can't afford it anymore and have bought a bike. This car has been awesome over the years, have had no trouble with it what so ever and runs like a dream. Always run on BP ultimate, and service it regularly. There are a few scratches around the body but nothing major.
This car includes:
full 3" exhaust going to blitz cannon
Greddy FMIC
New clutch - heavy duty cushion button (About 9 months old)
17" AVS rims
Apexi aftermarket suspension
e-nardi steering wheel
GTR body kit
aftermarket reverse parking sensors
turbo timer
front and rear strut braces
viper alarm system
Ill also chuck in 4 x 16" stock rims with decent tread, pod filter, stock muffler and a blitz BOV
It also comes with rego until Feb 2010. Any test is welcome.
I'm looking for around $11,500 but am willing to negotiate and would love a quick sale.
Give me a call and come have a look im located in S.E suburbs in Melbourne.
David 0402851987
Thanks
https://www.sau.com.au/forums/topic/290966-white-r33-for-sale/
Thanks mate. It's a 96, but not sure of the kit tho, could be a later year. I'm riding a 250 at the moment, so its alot cheaper then the car i get bout 220k's per 12L tank lol, but i've heard as soon as you move up to 600+ it starts to get expensive.
The car also comes with full aftermarket stereo system, including head unit, front speakers, rear 6 x 9's as well as sub and amp (not connected). The body kit is a genuine 40th anniversary kit, including the front bar, side skirts and rear GTR adjustable spoiler. This gives the car a very unique look.
The car also has a HICAS lock bar installed.
Nice car, but looking for something a bit for fuel efficient.
I can organise rwc aswell, including new tyres, new rocker cover seals, a standard steering wheel as well as e-nardi which is on now. Other stuff for rwc are only little things like some other seals need replacing, everything else is fine.
Car will also come with pod filter, standard wheels, stock muffler, blitz bov.
    • I have copied the images in the original post from photobucket to the SAU servers to make sure they stay available.
    • Mate you saved be from dying in the Perth summer. AC wasn't changing direction and just going into diagnostics mode fixed it. You're a legend and I would shout you a beer if I could!
    • Unfortunately effort gone to waste, you will have substantial issues with how the manifold and wastegate have been integrated. You would be so much better off with a modified stock manifold like this: https://hypergearturbos.com/product/rb25detexgatedmanifold/   OR literally just getting a off the shelf Sinco or 6Boost manifold as myself and others have mentioned.
    • Yuck. But it's kinda the same principle, moving timing around to make car run bad but sound good.... I went for a more spirited tuning drive to iron out a few things. Car no longer stalls, and it loved to dip RPM low when you clutch in. After tuning this (and the 4-5 tables that HPTuners/LS1 OEM ECU wants for idle air correction) it's now behaving somewhat normal. All expected because there's a new TB, new Intake manifold and that new TB which is 102mm vs 78... has an entirely different IAC passage which is smaller because ????? Unfortunately at this point I went to make further fine tuning changes to avoid it flaring up, you know... _tuning_ the HPTuners dongle died. Well to be more accurate - The USB cable died in a fashion that anyone who has ever charged a phone will recognize. After the app demanding I resync it 50 or so times (which all 'succeeded' but all failed) the device does not want to sync and I've logged a ticket with support to see if it's fixable. US Support said it was a 'storage issue' but after removing the SD card inside it and formatting it/fixing it the issue does persist. Unfortunately usually the fix is "Turn in your old dongle and pay $700 for the upgraded one" it's cheaper because I get some free licence credits I unfortunately don't need. However I'm 10 minutes down the road from HP Tuners AUS/VCM so at least I won't need to post it, and logged a new ticket for support over here. Definitely drives different. My SOTP dyno believes it's probably making 310-320kw instead of the 280 before.  It scrambles for traction a little now whereas it previously different. It drives like a bigger cam car up top even though the cam is smaller, likely due to the cam not being advanced 6 degrees. The timing is deliberately low and the fuel is very rich so who knows if this will improve on the dyno. It may, imperceptably. Also funny is removing the pineapples definitely makes the car squat more and axle tramp less. So this behavior of having more top end, squatting more, and scrabbling for traction more makes me think = more power. But I could have just been sitting on the threshold of that kind of behavior before. Time will tell if my butt dyno is calibrated right. I need the exhaust leaks fixed before dyno tune for obvious AFR related reasons - I repositioned the pipes but I'm not confident it's fully sealed even if it is better. At least the car does drive around while I cannot tweak/tune it for now. And I have aircon again. medium success!
