yeah that would be awesome haha,m cheers for the heads up on the cam gear i'll check that next time i have to pull the front apart. could well be the case but right now im pretty sure its the diff ratio.
tacho is stock s14 tach. works.. just reads wrong.
i dont think the output of the neo ecu would be strong enought or be putting out the right frequency to run the s14 tacho. the r34 tacho is controled by its own ecu so its not like a conventional tacho.
does the neo loom have the link to hook up a timing light like the rb20 and 26 do? if so id tap into that and run an am tacho. any decent auto electrical place that does gauge work would be able to make the tacho work with a vdo unit.
thanks mate!
im a little peeved atm.... my mate just made 296 rwkw with same turbo, same sized gate, on a s2 R33 rb25 with better power up top, where as my neo comes on earlier and harder. lol im not seriously annoyed but its interesting to compare!
he has no vct and an RB20det inlet cam in place thats the only difference
praccy day run and done.... only lasted 3 laps before issues. IO knew there was going to be heat issues with a high mount turbo so i bought some of that expensive heat sheathing stuff that you slip over your pipes and wiring. not cheap at 60 a meter and what do you know.. it doesnt work too well. The wiring loom for the oxy sensor melted together and shorted out which killed the engine out on the track. lucky was at the start line when it happened. so got back to the pits and sorted out the loom, was worried more was done and thats why it wouldnt start.
once i unplugged the oxy sensor it started. so we thought all was good. repaired the wiring and relocated it well out the way then started it ready to go out again and noticed it was only running on 5 cylns
checked all coil packs first up unplugging them one at a time with the motor running and found number 4 not running. pulled plug and pack out and tested for spark and that was ok... only thing left was fuel and we couldnt test the pulse for injectors at all since no one had a node light. pulled the CAS out with motor off and slowly turned it by hand and counted the injector clicks, only 5 clips per cycle.... hmmmmm
checked wiring loom and went down to the ecu area and and soon as we stuck our head in there could smell that dreaded burnt circuit board smell... pulled it out and opened it up and sure enough.... a burnt transistor and injector driver for number 4 so that put an end to the night :laugh:
over all happy with the car, just need to fix the binding issues at lock and change the diff ratio and it should be sweet as! Jeff thinks he can repair the ecu so fingers crossed!
couple pics from my 3 only laps.
http://www.youtube.com/watch?v=m6O7hVcDme0
Edited by Simon-R32
ey man i just read your thread and watched your vids looks like so much fun im only 16 at the moment but i definley wanna get the no how and skill to drift 1 day looks like sooo much fun.. and loving the s14 looks sexy.
Got my derlin bushes and rear knuckle bearings in now... ended up doing them myself cause a few shops didnt want to touch them (derlins are very hard material and dont go in easy like poly bushes) had to press them in and use a vise to squeeze the knuckle bearings in.
all in all shit loads better then the stock rubber shit so should be good to see how it goes!
Massive thanks to Cazman for devoloping and manufacturing these parts. if your after some they are available through Cazman.
bit of a set back now :laugh:
manifold is off being modded and also we're getting it ceramic coated.. also wanted to do turbing housing so i took that off and what i found was not pretty :D turns out something must have gone through it and turbine is damaged... kinda explains the lack of power also... also glad i caught it now rather then have it explode mid thrash!
take note of the missing chunk!
    • OK, that is a helpful description, because that sounds exactly like a bleeding issue in the clutch....these are hard to bleed manually even when the damping loop has been removed. I'd suggest bleeding again....start by filling the master cylinder up and opening the bleed nipple. Come back and check every now and then that the master cylinder is not empty. Let it gravity bleed for a few hours and see if that improves
    • I replaced the whole clutch line with the chase bays braided hose, I think it removes that loop, is it the short hose that comes immediately off the slave or is there a drawing in the manual to find what you’re referring to? It was just re-bled when I upgraded to the nismo slave, old slave worked fine but I thought that might help, didn’t change a thing. It’s like the first half of the pedal is pushing air and then when it finally actuates the master the friction zone is tiny. Makes it practically impossible to launch the car
    • Yep, that was one of the things we learned fast in the past with our MX5. When you drive with the top down, you are effectively standing out in the sun, 100% of the time, and not getting in any shade (because roads aren't shaded generally!). Just like standing out in the middle of a field on a sunny 27C day is a bit of a bad plan, so is sitting in a MX5 without sun protection.
    • I also just ordered some Frankenstein bolts and side mounts to fit a hard top Just in case I do find one, basically so it doesn't need to be fixed to the car with only the front latch.......and then gaffa tape to keep it in place for the RTN journey from wherever I get it
    • If your temps are fine now, you probably won't have any issues with where your vents are as they don't look right up at the windscreens high pressure area, so any differences when giving it the beans for extended happy laps would be minimal, but, they should vent heaps when stuck in traffic  Much like how that reverse cowl on my SS let "visible" heat out when stationary, but, because it was basically at the windscreen my coolant temps on the Hwy actually raised because air was being fed into it at speed (110kph), to only come back down to around 90° when I got off the Hwy And your 100% correct about the NC currently not needing vents, but, if I was to add a turbo, and a oil cooler and intercooler in front of the condenserand radiator, and then take it to the track???? It is apparently a recommend requirement if I don't want to worry about coolant or oil temp issues, but, any of the above are possible scenarios, over time As it sits now, with the triple pass radiator and stock air conditioning system, I have absolutely no issues with either temps or air conditioning efficiency, I've been basically daily driving thie car for the last month, both on the Hwy, and peak hour, bumper to bumper traffic, but, that's pretty much expected from basically a standard engine  Talking about no issues daily driving, it was 39° the other day and I was sitting in bumper to bumper traffic on the M5 and then M7, with the top down, and with the air conditioning blowing nice cold air on my feet, balls, and face, well, there was one issue, my head and arms got pretty sun burnt Note to self: leave a hat and sunscreen in the car for such days 🤣
