comp test isnt 100% accurate and i did also say i used the workshop comp tester which has been known to read lower. either way.. it goes hard. i have no issues with the motor so far. BTW what are the CP's you have for sale for the neo?
Yes pistons are for a Neo engine.
I just thought it was abit weird my engine(neo) was reading significantly lower than than an RB26 which was tested on the same gauge.
i could be interested... need to assess my finances.. PM me with a price for them if u can.
I fitted my GTX today...
a read can be found here http://simonmichelmo...ing-new-gtx-up/
Hey champ, when is the Dyno happening?
What is different about the nuts you used on the turbo??
nah these arent the off centred ones.. they have a slit at the top or crown of the nut and as you tighten them up then deform and lock into the thread... and yeah everyone should beusing them but i havent been :S
as for dyno will be another week away... got heaps of shit i need to do to the car before its down back on the ground.
for now.. heres some things to check out.
Driver profile for WTA
http://www.tectaloy.com/tectaloy_tdc2011_dp_sm.html
Ah ok, do you find they are better or worse than the ones I'm talking about?
Also what did your neo set you back when you bought it?
paid 1500 for the neo...was mising the turbo but everything else there. not bad for a cheap motor!
these nuts are so much eaiser to put on... they go like a nylok nut.. so single use item only really.
i think they are called Crimp nuts. atleast thats what i ask for when i got to my local nucts and bolts. they are the ducks nuts for keeping turbos on.
bargain, I'm picking a neo up for 1900 this weekend, bare motor as well. Still it is the only one I've found for under $2k and in Adelaide in the last 2 months.
Where do you get the nuts from? I need to get some new ones so if they are easier to put on I'll grab them instead.
you in adelaide rolls? i never knew.. if you need a hand with anything or wiring related hit me up.
nuts from MTQ.. pretty cheap!
got my WTA confirmation!
http://www.worldtimeattack.com/index.php/south-australian-g1-champion-simon-michelmore-confirmed-for-tectaloy-drift/
Yeah I'm in good old Adelaide, already converted the 32 to a 33 25, but putting a neo in as it shit itself so hopefully will just be the CAS plus I need to rewire and that's it!
Cheers for the offer. :)
edit: Didn't realise you used rsr's on the car, that must cost an absolute fortune with drift!
Edited by Rolls
  • 3 weeks later...
update: Garage7 repaired my BC coilover and Hoey are regassing it for me.. with some luck i'll have it in next few days.
started mounting my air vent... as typical i cut the hole too f**king big :( oh well this front bar has a limited life span anyway... my painter cant paint it before matsuri so i rattle canned it lol.
Hey rolls, are you going to use the 33/32 loom/ecu/ign set up to to run the 25 neo? what are you going to do with the CAS? is it as simple as a plug re-wire and use the neo CAS or do you have a mechanical solution to put the rb20/ r33 rb25 CAS into the NEO?
Cheers
Justin
I am using all R32 loom up to the ignitor, I chopped the old plug off and used the R34 coils that have the ignitor built in and wired a nice new deutsch plug on the end removing the ignitor, plug looks better than factory! about $35 for all the pins etc but I know it will last forever now.
Using rb20det R32 ecu with a nistune module, R34 cas rewired (pin out is different) 1-4 2-3 3-4 4-1, Z32 afm and S1 r33 intake manifold with aux air valve, throttle body, tps etc. Basically looks like S1 rb25det everything with r34 coils.
Try and get a complete R33 intake/fuel setup etc as the r34 sensors etc are all different, different coolant lines etc, different fuel rail and injector loom, so have no idea how it would all mount up.
    • I have had the r3c in for years now, maybe close to 7 years and it has never missed a beat, anyone can drive it. Super easy to drive around town, the hotter it gets does get a little hard but it holds the power easy as
    • Shit thing to find eh? I guess the big issue is that whatever "fix" you do now, it might slow the rust down but won't fix it. I just wanted to add that in no way is fixing sheet metal in 3 dimensions the place to start with welding....that is a pro only job because its too hard to work out where things should be, let alone doing a clean enough job that it can look OK and still be strong too.  I needed to get a new rear quarter panel on the GTR and it took a pro weeks to get the old one off cleanly, new one on in the right place and looking somewhat like it should have with most of the previous connecting panels in place. Gluing a couple of bits of metal together with a welder in the garage is doable, but that is totally different to doing panel  replacement
    • This seems to be a very popular swap since all the turbo skyline prices went through the roof! I'll let someone more familiar chime in, but I understand that yes you probably want to swap the loom in to swap out the auto TCM stuff. You should not assume everything just plugs in either, you need to check at least the ECU wiring diagram for any differences at the plug at the left headlight and probably the ones near the ECU that join the dash loom too
    • hows it fellas, my first post here which seems crazy cos half the forums i read are like the same age as me haha. to make a long story short ive got an r34 sedan (rb25de neo auto) which im swapping to a s0/s1? rb25det, r33 big box and nismo gt pro lsd. i have the motor and gearbox all bolted up outside the car, old motor and trans out. i bought the motor with stock ecu and loom, do i switch over to that? or will it be easier to get a r34 manual ecu and keep the loom if thats even possible.  also engine mounts look different, anything else thats different or incompatible? cheers, hope this all makes sense Paddy
    • att.4QNbuJlz_gNZPFBGFqeEvxSUHXkGt7z40V59MrtXTPg.mp4
