Shit that may be a good enough reason to head all the way down to SA tongue.gif
thanks for that mate. glad i can be inspirational some of the time haha I'm starting a drift school up in SA soon if your nearby. could be an easy way to get into it.
Hey Simon,
Just skimmed thru ur build. U have done a great job with the car, and i must say, it does look awesome with the 180 front.
there are some great photos and video of good driving bro.
Congratulations on ur achievements in Australian drifting of 2011.
Good luck on ur next list of mods and hope get back out there asap and to skidd again!
All the best
Cooper Customs
Edited by Cooper Customs
thanks for the feedback mate! much appreciated.
progress has been slow with xmas and new years... getting back into it very soon.
oh and i have also been working on my other car.. slapper 180sx with VL RB30E in it converted to turbo with RB20 loom, CAS, Rb20 ECU and RB20 injectors... got it all running and hope to do some skids in it soon haha
UPDATE:
well i got busy and finished the slapper car in time for a private new years party we had... car's done, and its truely epic haha.
some pics and video of it in action. engine only running 5psi boost, tune was done at the track using a wideband only. limiter set to 5800 rpm and yeah... sooo much torque lol has no troubles baking the rears.
Edited by Simon-S14
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
