Needs side skirts and front bar support yet
Had it on the dyno yesterday.. had some normal teething issues and some not so normal once.. had oil leaks and coolant leaks everywhere...including a leak from the radiator :/ anyway sorted that shit out and then started the run in process. the engine was run in for a bit with some hard core load by holding it at 4000 rpm and then increasing the load, did that for a bit and its sweet... engine runs and sounds great. however once we started getting into the tune we found it would just missfire like crazy at anything over 4000 rpm and 12 psi boost.
Decs tried pulling fuel and timing out, adding fuel and timing and a combination of both, nothing made a difference. we tried gapping the plugs down to 0.5mm then 0.8 and then 1.2mm. none made it better. Coil packs were brand new 34 GTR Splitfires. only thing we can put it down to was faulty coilpacks.. so that effectively ended it for me. On top of this drama i have a clutch that doesnt disengage properly.
as you have just rewired it your miss fire may be being caused by electrical interference into the CAS wiring. running the 2 white shielded wires near the coil packs or to close to the injectors or anything that may cause electrical "noise" can make the ecu miss read the signals. when i wire rotaries it is very important that the ignition wiring and crank signal wiring are separate as they are prone to misfire then killing engines.
i have also had CAS die randomly and they will cause an under load fault. checking on the ecu shows it should have X amount of timing but checking with a timing light shows actual ignition timing far less. will be fine untill load is applied.
im sure you have checked it but fuel pressure will also cause a miss under load. not sure if you have put a gauge in it yet but as your lift pump was faulty you may still have an issue. depending what brand E85 you are using it may be killing your pumps/injectors. i know of local racers that have had 2 or 3 pumps go in as many events due to the brand/quality of E85. this is because E85 is Hydroscopic and will take in water. E85 manufactures are allowed to add a small amount of H2O to the mix but this can and will cause seizures of pumps and injectors.
hope that gives you a few leads if you done have it sussed already.
new loom is a haltech loom, comes with shielded cables for the CAS and triggers. Cas wiring runs under the intake manifold where as the ignition wiring runs from behind the head straight to the valley cover. I doubt thats the issue. We initially thought a faulty CAS or wandering signal might have been the issue... i held a timing light on the timing marks while decs ran it up to the point where it would missfire and the timing did not move around at all.
fuel pressure is spot on.. 40psi at idle and rises to 60 psi by 4000 rpm + boost pressure. does not move at all also.
    • My hold point for future mods is that I want a OEM detachable hard top first, but, finding one is a pain, MX5 Mania are looking for one for me, but, as hens teeth are more common, finding one in Australia is proving problematic  I can get a OEM one from overseas, hell, you can still get new ones in 'Merica, but, shipping is a absolute killer and I cannot justify the cost, or the risk of it being damaged during transport As for the aftermarket hardtops, whilst they do the job of being a hard top, and are fine for a track car, they don't seal well (read: leak like a sieve in the rain), and you need a plastic/poly rear window, plus they are a bolt in option only and not made to be easily removed I liked how the hard top on my NB could be fitted, and removed, by myself, in less than 5 minutes I know it sounds bad, but I'm waiting for someone to write off a car with one so I can swoop in on their pain, it will go to a good home though, so my guilt of this is tempered
    • I’ve got one on mine and it’s fine,
    • No, you don't want to plug the vacuum line, as that will turn that side of the booster into an air spring and probably make it feel worse. I'm not saying that the GTR master itself doesn't need a booster. I haven't paid attention to the GTR one to know what size it is cf the non-GTR ones. But when you think about it - they have to do the same job, which is to move a little slave piston a few mm to do what it is supposed to do, and that final action is the same on all the cars. So, it is very unlikely that the GTR MC is any different than the others, because it has the same pedal stroke and the same output requirement. The booster just makes it feel easier. I'd suggest you probably have an actual hydraulic problem. It's totally common on these old shitboxes.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
