shakedown today at mallala... first time out and i had all sorts of cutting out issues... would just cut out big time in the midrange when on the throttle.. was hell weird. it wasnt until Decs from Garage 7 came along for a passenger ride and said its boost cutting. the target boost is set to 18 psi with a cut out at 22 psi to protect the engine from overboost (plus the map sensor only reads to 22psi so cant set higher) for some reason on the dyno it never spiked but on the track with some hard throttle mashing it spiked to 22psi and cut. so we backed the target boost back a few psi and problem solved.. now peaks at 18psi and doesnt overboost.
once that was sorted have it some hard laps and was pretty happy with the overall performance.. its a little bit lazier coming onto boost but once it is it just pulls hard. didnt bother going for lap times as i was running shit tyres and drift set up. was all over the shop with shitty half worn sunnys on the back lol.
Good to meet you mate sorry I didn't get to take you for laps. Had issues then Decs from garage 7 rocked up and got stuck into data logging it. Found boost was spiking and cutting rpm.
that's cool Simon there's always next time, car sounds great with new setup!!! All the best for Tassie :thumbsup:
Quick question with the dyno graph simon, with the rb25 head and stock cam you made same power on 98 and more torque than you are now with 26 head and running E85. I know your making less torque because of the manifold but I thought you should have see a max kw jump from the e85 and 26 head.
nah what happened was when we first tuned it with BP98 and stock cams it was tuned on the dyno with no temp correction turned on. cause there was no temp probe so the dyno software automatically assumes 100 degrees ambient air temps. hence the inflated power and torque figures.
it means that the very first tune that we did on the first set up was out of wack yes... then the owner of the dyno (not my tuner, different person) purchased a temp sensor for the dyno so we were able to tune correctly from then on.
anyway.. bottom line is, yes its down on power but once cams and cam gears are installed it should bump it back up
wow what an insane read from 1 to 41 tonight, awesome build man, im also in the process of building my 32, will hopefully be going too the same depth of mods as you on mine, might see you on the track!!
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
