Was good to finally see this thing in action :thumbsup: had followed it from the NEO days, was gunna come say hi but like i said you looked like you were pretty busy so i didnt interrupt :)
I'll make sure I do next time mate :) was awesome to finally see the beast anyhow!!! Your vid of the car back with the NEO and 38mm gate was serious inspiration lol..... Finally got tuned and can't keep the thing on the road, suspension shit itself, brakes shit em selves, clutch just shat itself lol.... Awesome so far lol
The stock nissan bottom end doesn't have any inherent weaknesses at the power levels most people run, it has the nissan seal of approval unlike many aftermarket rebuilds that grenade 5000kms later and it is also extremely cheap.
Imo almost all motors that do grenade are due to oiling issues be that starvation killing the bottom end, assembly issue (wrong clearances etc), limiter bashing unbalancing things or a tuning issue causing detonation via one of many ways killing the bearings and pistons.
So knowing this I don't know why everyone doesn't just go a stock untouched (unmolested) rb30 bottom end, chances are you will kill it from one of the reasons above well well before you destroy it due to high revs destroying the rod bolts/rods or destroy the pistons/bearings from just simply too much torque.
While I agree with you on the most part, keep in mind this is a drift car...
been going alright so far.. oil control has been settled for now with the use of an Accusump which works well... should have got one a long time ago.
stock NA RB30 bottom end has been proven to be reliable up until around the 600 hp mark.. fairly impressive really! obviously limiter bashing and drifting puts more strain then most of motors so we'll see how it goes.
  • 4 weeks later...
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
