Was good to finally see this thing in action :thumbsup: had followed it from the NEO days, was gunna come say hi but like i said you looked like you were pretty busy so i didnt interrupt :)
I'll make sure I do next time mate :) was awesome to finally see the beast anyhow!!! Your vid of the car back with the NEO and 38mm gate was serious inspiration lol..... Finally got tuned and can't keep the thing on the road, suspension shit itself, brakes shit em selves, clutch just shat itself lol.... Awesome so far lol
The stock nissan bottom end doesn't have any inherent weaknesses at the power levels most people run, it has the nissan seal of approval unlike many aftermarket rebuilds that grenade 5000kms later and it is also extremely cheap.
Imo almost all motors that do grenade are due to oiling issues be that starvation killing the bottom end, assembly issue (wrong clearances etc), limiter bashing unbalancing things or a tuning issue causing detonation via one of many ways killing the bearings and pistons.
So knowing this I don't know why everyone doesn't just go a stock untouched (unmolested) rb30 bottom end, chances are you will kill it from one of the reasons above well well before you destroy it due to high revs destroying the rod bolts/rods or destroy the pistons/bearings from just simply too much torque.
While I agree with you on the most part, keep in mind this is a drift car...
been going alright so far.. oil control has been settled for now with the use of an Accusump which works well... should have got one a long time ago.
stock NA RB30 bottom end has been proven to be reliable up until around the 600 hp mark.. fairly impressive really! obviously limiter bashing and drifting puts more strain then most of motors so we'll see how it goes.
  • 4 weeks later...
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
