Just got two of the 16" spal high performance fans that flow over 3000 cfm air each... so a potential 6000 cfm air flow. overkill much? probably but thats the idea... this cooling system would be right at home in a burnout car soon :)
mounting them on the radiator in this sort of shroud, excuse my MS paint skills..
I do agree with mungy.
Pull air from the quarter panels.
I read a build up thread on a GTR that had done the same thing as you. They cam to the conclusion that using the quarter glass as the air inlet was the bes.
They made up full carbon fibre ducting from each side into a main funnel of the rad. Fan was mounted underneath the rad in a pull config.
Not sure about the above design there simmo, I think for a rear setup pushing air through the rad won't be as effective as pulling it through as you will create some turbulence before the air goes through the radiator slowing it down, you should mount the fans underneath the rad and have the rad COMPLETLEY sealed between the fans and the ducting to get the best flow through the rad.
the fans are pulling through the rad.. that pic is just inverted thats all.. and yes its completely sealed.
kitto, i know about that red GTR in the uk that your referring to.. its brilliant stuff. at same time theres no reason why air being fed from the roof wouldnt work as its a constant high pressure zone when straight or sideways.
Don't mind the caps lol, I phone seems to think it knows best, yes you are right it is a high pressure zone but doing it that way will make your fans work harder than if we took the air from the quarter panels, think of it this way if air is basically a much thinner lighter version of water and if you were drifting under water which way would help the water flow to the radiator easier?
to be honest i may end up doing both side vents and top roof vent to supplement it cause i need all the air flow i can get. I need some ducts or vents made for my rear 1/4 windows.. anyone able to assist with that?
not sure about your theory on high air pressure making the fans work harder.. if the air pressure is higher due to ram air effect then fans will most likely be off due to the large amounts of cooling air flowing in. and besides think of all the factory themo fan cars with their rads in the front getting ram air from high pressure air
Simon, can you give us a quick review of your front susp set up?
Cheers
Justin
parts are GKtech knuckles which Garage7 modified the steering arm to my spec, we then drilled out the bolt holes and fitted longer bolts (these were prototype knuckles, the production ones have this already done) we also ran a weld on the join to secure it. i wont be changing the steering arm every 5 mins so i'd prefer it to be solid.
coilovers are BC ER with 8kg fronts
LCA are OEM s14 lengthened 30 mm with a recessed area to allow the steering arm to travel more
Tie rods are off the shelf OEM replacement parts, Tie rod ends are my own design
Bolt on rack spacers are my own design. allows 20mm extra rack travel
Castor rods are offset GKtech items
Swaybar is stock.
