Have had no issues at all with it and runs very well. Doesn't ever stall on me and idle control is perfect. I rate it that's for sure. Pulled pipe off to do cams not long ago and inspected ATM and was faultless. I dont think 20 plus psi is an issue at all as I've been running 1.4 bar. However time will tell. I couldn't see the plastics lasting 15 years like that haha
from the downforce mate... i hit 200kph a few times on back straight and every time i do that the boot gets slightly worse lol. The origin GT Wing is suppose to provide a full 110kgs of downforce at a certain speed at full deflection according to an option mag review on various different wings.
I got the wing from MAD Automotive here in adelaide.. great trader and have lots of parts in stock for nissans.
  • 3 weeks later...
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
