yeah i'll get onto the name change lol. you injectors should be fine but doubt the pump will keep up with the flow. if you cant be bothered going twin pump look into a much larger single pump.
on another note.
got my head off atm to hopefully fix cooling issues.. anyway heres some pics of the 25 which is stock bottom end pushing 360+ rwkw... everything looks mint!
i got another bottom end that im going to start building up on the side... so if something happens i'll chuck that in.
as for the cooling issues.. well first i need to find the prob. head came back with zero faults. could still have been gasket issue. i'll take the water pump out next and then go from there.
thinking i might ditch the alloy rad to and just run a GTR oem radiator
started at winton.. would just push water out the rad and boil then get hotter and hotter. have changed thermostat, clutch fan, and radiator cap.. didnt solve it. pressure tested, leak down tested and comp tested ebverything and didnt show any faults. someone suggested a possible head or gasket issues so i thought f**k it i'll pull it off and do MLS and ARP studs anyway. so thats what ive done so far
heres a left field thought.
what about the bonnet? the new venting setup? i did a quick search back throught your pics and the issue has only accured since changing bonnets? and everything tests ok?
just a thought as whist vents are good they can cause other issues. just throwing that out there.
well its time for an update!
Got ARP head studs and a MLS gasket thro Garage 7, Head work was done by Rhemac.. all came up good :D
and back together and running again :D
And then the car went to All Type Crash for some major repairs after Winton Matsuri... the colision with the falcon left the sil panel and door frame pretty bent. The guys down at all type managed to pull it out and bring it straight again and along with a new door you'd never guess anything happened!
3 drift cars.... awaiting repairs!
before
and all fixed... check out my older pics to see the damage.. i never took any pics when the door and panels were off but it was fair major. looked a lot worse then. its a major feat to see that they managed to pull it out this well.
Edited by Simon-S14
hey mate, if you end up rebuilding a bottom end fit for the NEO, let me know who you get the pistons through, ive been searching for a while and cant find anyone who has NEO pistons, i can only get custom ones made if i send them in my old ones, but i cant afford not having my car for weeks on end
Whens the next time you go to winton!? I only just went drifting for the first time in my track pretty much stock 33 (for now) and i'm hooked. Would love to come down possibly and take some photos at a drift matsuri! NSW needs more dori!
I have a set of Neo pistons ready to go ....
My linkhttp://www.skylinesaustralia.com/forums/topic/337011-rb25det-neo-cp-pistons-865mm/page__p__5449423
I noticed you that you compression tested your engine and it was reading low (90psi) but still pushing decent power or didn't feel like it had lost any power? Can you or have you comp tested it again? Would be keen to know what reading you are getting now.
Edited by aleks
Dec's from Garage 7 did a check up tune last night on the dyno since i had pulled the head off and motor apart.. was worth while just making sure all was ok before it gets some more thrashing this weekend.
so as it was.. with the motor thats seen a crazy amount of thrash time and has been reliable as hell.. and overheated a few times recently. it still makes crazy power. in fact its up 10 rwkw since last time lol. Dec's pulled 2 degrees of timing out and dropped the boost half a psi and all was sweet. I would run 20 psi but the AFM maxxes out right about then ;)
heres a dyno chart. with no temp correction it makes 405 rwkw and with temp probe and actual power output its 367 rwkw. but the best part about it is the fact that at 4000 rpm it makes 180 rwkw. more then most street cars lol
Edited by Simon-S14
thats some impressive power, the bottom end is still stock right????
KW figure is very impressive, but i was expecting a heap more torque, thought you would hit the 750-800nm of torque.
however, what clutch are you running??? also have you modded/rebuilt the gearbox in any way???
    • I was more thinking so it doesn't flop around as much rather than for rotating it. Once you have the balance right, it should rotate well enough, depending on how much resistance there is on the pivot. I think you said the pivot point was on a bearing though didn't you?
    • You can get them with the worm drive rotator but I was too tight to pay another $250-$300 so manual labour it is! I don't think it will be too hard to rotate though.
    • Sag as in the windows start to slowly open themselves, or they're just slow to go up/down with engine off?
    • It looks like it needs a big worm gear drive on it to control the rotating, not a few sloppy pins!
    • As Duncan said, first there was OBD, which few cars used, then came OBD2.   Now an interesting point, OBD2 isn't even for what you want to do. OBD2 is for emissions testing. There is some sensor data on OBD2, but it's up to the manufacturer what they're putting on it. Most scan tools operate on UDS, which like OBD2 is a standard built on-top of CAN. UDS specifies how to structure a message, what very limited things mean such as "read memory address" but it does not specify what is stored in which memory address, that is all up to the manufacturer. You either a scan tool compatible with that vehicle, or to know how to reverse engineer all the data, which can take a VERY long time and a lot of vehicles to get it right. Oh and then the manufacturer does a firmware update and changes what's where... Ask me how I know that as fact Oh, and by the time you've got the scan tool that supports all the manufacturers stuff, well, you're back at "But a consult cable and the Nissan software" The main difference being most manufacturers software these days works with the same hardware readers, as the readers are built to support J2534 which is another standard for how the PC communicates with the tool to make it do specific things on the car...
