well ADGP was freaking AWESOME! words cannot discribe how good and well run this event was! i i'll use pics and vids instead haha :D
road tripped it over there. left 5am fri morning to get to calder at 3pm to set up and unpack.
my car was faultless and performed brilliantly all weekend only issue i had was a bend tie rod and castor rod bracket being out of wack after a hard hit when tom monkhouse spun in front of me. steering wasnt the same afterwards but being the drifter i am i made do with what i had. was running some crazy toe out at the end... something like 30mm out. flicks in HARD hahaha.
Your car looked good out Simon, the rear screen sunvisor thing is cool!
Fixed the video links, for some reason youtube provides the wrong links for original hot-linking.
Your code:
http://www.youtube.com/watch?v=oKNBd8EavWI&hd=1
What it needs to be:
It's the extra "&hd=1" thats telling the video to go to HD 720p, it doesn't like to be hotlinked for some reason, might be cause HD video wont work in a forum size box as well. Will look into it anyway.
You were out @ opposite sessions to us which was a bit of a PITA. Next time hopefully it'll workout a bit different with sessions.
Plus us Track Battle guys all know each other, so we all went to a pub (about 10mins away) for lunch both days as we had 2.5hrs between mornin/arvo sessions so i think we spent a good 1.5hrs chillin there enjoying Lemonades... :cheers:
I reckon it was a great event, you drift guys really did some epic carnage to your cars and each other. At one point we were trying to pick which cars weren't gonna come back with damage, was great viewing indeed! Was really well run from the Track guys perspective.
How bout you guys? Looked like it was running well?
cheers. i wish it was a tad louder... if my car sounded like that Red 33 high tech oils one i'd be quite happy haha.
was a great event.. as you said mega carnage. was my good mate in the blue 32 who wrote it off earlier on in the sat so was a real damper on the moods to start with. very un forgiving layout but we all had fun. as you can see drifters are a uncaring bunch.. most were going for broke lol.
the time attack stuff was a great idea to put with it... it gives the crowds something else to watch. and the sounds from the cars going full noise all the way round the dome while standing in the middle of it is brillant! i had no idea what sort of times people were doing as the PA down our end of the pits was lacking big time!
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
