The CeCe cefiro (i think it was?) - one of the surprising sounding i reckon.
We were thinking 1JZ or something a tad different, and then bonnet goes up - 26/30, very surprising the note it was giving :O
  • 4 weeks later...
not much of an update.
bought some driftworks rear hubs and they dont fit my car :(
closer inspection sees the trac arm, and camber arm fouling the driveshaft on susp compression.. in pics the susp is unloaded
so put back together and went skidding for sats prac night.
haha cheers! i got back yesterday from drift attack... qualified 1st over all and came 4th in the end.. had some issues with my eye sight (got a rock in my eye earlier in the day and it got irritated badly) so im lucky to be able to do as well as i did.
DJRIFT: they suggested i buy driftworks arms... which are just china shit painted orange :S i will be able to make it work but its just a PITA
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
