Shit that may be a good enough reason to head all the way down to SA tongue.gif
thanks for that mate. glad i can be inspirational some of the time haha I'm starting a drift school up in SA soon if your nearby. could be an easy way to get into it.
Hey Simon,
Just skimmed thru ur build. U have done a great job with the car, and i must say, it does look awesome with the 180 front.
there are some great photos and video of good driving bro.
Congratulations on ur achievements in Australian drifting of 2011.
Good luck on ur next list of mods and hope get back out there asap and to skidd again!
All the best
Cooper Customs
Edited by Cooper Customs
thanks for the feedback mate! much appreciated.
progress has been slow with xmas and new years... getting back into it very soon.
oh and i have also been working on my other car.. slapper 180sx with VL RB30E in it converted to turbo with RB20 loom, CAS, Rb20 ECU and RB20 injectors... got it all running and hope to do some skids in it soon haha
UPDATE:
well i got busy and finished the slapper car in time for a private new years party we had... car's done, and its truely epic haha.
some pics and video of it in action. engine only running 5psi boost, tune was done at the track using a wideband only. limiter set to 5800 rpm and yeah... sooo much torque lol has no troubles baking the rears.
Edited by Simon-S14
    • Ok guess I can rule out the battery, probably even the starter and alternator (maybe) as well. I'm gonna clean those leads and see what happens if it's still shit I might take it to an auto electrician. Unless the immobiliser is that f**king heavy, but it shouldn't be.  If I start the car every day, starts up perfectly never an issue.
    • Anything above ~9.5V is acceptable. The higher the better, but it will almost always drop to at least 10.5V, if not lower, even with a new big battery and everything else being good. 9.76 is not a concern. If it goes below 9, you'd be sure that there's a problem with either the battery or the connections.
    • It's new almost. Under a year old i think and I've tested it twice at supercheap
    • Glue the head from a Pez dispenser on it. Goofy, or Winnie the Pooh, so something.
    • Adjusting the idle screw is usually (emphasis on usually) just covering up deeper issues. Stuff like the cold start valve not closing properly. Throttle shaft seals on the way out. Coolant temp sensors getting out of spec. Coolant temp sensors especially can be a bear to diagnose because they can fail subtly. My dad just spent weeks chasing down his high idle. He cleaned the coolant temp sensor and everything but the resistance curve just drifts over time and if it's been 20+ years they also get super slow to respond as well. Has a massive effect on fuel economy as if it's off the ECU is going to run richer and command high idle for far longer than it should otherwise.
