shakedown today at mallala... first time out and i had all sorts of cutting out issues... would just cut out big time in the midrange when on the throttle.. was hell weird. it wasnt until Decs from Garage 7 came along for a passenger ride and said its boost cutting. the target boost is set to 18 psi with a cut out at 22 psi to protect the engine from overboost (plus the map sensor only reads to 22psi so cant set higher) for some reason on the dyno it never spiked but on the track with some hard throttle mashing it spiked to 22psi and cut. so we backed the target boost back a few psi and problem solved.. now peaks at 18psi and doesnt overboost.
once that was sorted have it some hard laps and was pretty happy with the overall performance.. its a little bit lazier coming onto boost but once it is it just pulls hard. didnt bother going for lap times as i was running shit tyres and drift set up. was all over the shop with shitty half worn sunnys on the back lol.
Good to meet you mate sorry I didn't get to take you for laps. Had issues then Decs from garage 7 rocked up and got stuck into data logging it. Found boost was spiking and cutting rpm.
that's cool Simon there's always next time, car sounds great with new setup!!! All the best for Tassie :thumbsup:
Quick question with the dyno graph simon, with the rb25 head and stock cam you made same power on 98 and more torque than you are now with 26 head and running E85. I know your making less torque because of the manifold but I thought you should have see a max kw jump from the e85 and 26 head.
nah what happened was when we first tuned it with BP98 and stock cams it was tuned on the dyno with no temp correction turned on. cause there was no temp probe so the dyno software automatically assumes 100 degrees ambient air temps. hence the inflated power and torque figures.
it means that the very first tune that we did on the first set up was out of wack yes... then the owner of the dyno (not my tuner, different person) purchased a temp sensor for the dyno so we were able to tune correctly from then on.
anyway.. bottom line is, yes its down on power but once cams and cam gears are installed it should bump it back up
wow what an insane read from 1 to 41 tonight, awesome build man, im also in the process of building my 32, will hopefully be going too the same depth of mods as you on mine, might see you on the track!!
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
