Spent all weekend on the cart prepping it for Calder park coming up. Basically needed to fix oil leaks and stuffed rack bushes so I went up to garage 7 and ripped out the cross member, rack and sump. While it was all apart I had planned on upgrading the oil pump gears with reimax gears for reliability, couldn't get any in time so went with spoil billet gears.
Anyway pulled oil pump out and found the housing was scored to hell. The spool great was also way too loose on the crank collar with clearances about 20 thou on each side. Max allowed is 11 thou. So that ruled that out.
Only quick solution available to us was to fit a complete nitto pump. Garage 7 had one on the shelf luckily. Measured clearances with collar and was perfect.
While the sub frame was out I got Decs to cut and reposition the rack further forward. Came out mint, chucked some new rack bushes in and re sealed the sump and put it all back together. We also fitted a 3 bar map sensor and did some fiddling with the boost control to avoid the over boost cut issue I was having.
Just need a touch up tune and wheel alignment and I'm set
    • For something like this, I'd skip just going for the cheapest, I'd find the place with the best experiences people have had, especially for restoration work. Like everything, there is upholsterers, and then there is upholsterers. Some really great upholsterers for automotive restos won't even appear to have an online presence.   My guide would be find some of the old school classic cars that have been fully restored and are immaculate, and ask the people who own them who did the work on their seats
    • Might be tricky matching the seat trim material  If your got the funds you "may" want to get the rear re-trimed as well to match the front
    • How much is it to re-uploster?  Well that's a "how longs a piece of string?" question !  And I answer thusly: "twice half its length! " . . . . . .  Seriously you'll have to chase multiple quotes for that one from different uphlostrerereres !  Ask around, in your area and on the forums, chase reviews and most of all see the finished product in person cause photoshop is a wonderful thing !
    • Hey everyone!!  I've noticed that whenever I do my oil changes, after putting 4L in, the oil level sits at the top mark in the dipstick. This is after letting the old oil drain for a very long time too! I've checked the oil level daily for the past few mornings. It happens every time and it's confusing because all the threads say that it should take about 4.7L (With some just adding the full 5L) My next thought is to figure out if the dipstick I have is correct so could someone please tell me the length of the RB25DET engine oil dipstick?  I've checked images of some of the genuine dipsticks, but none of them have the length in it. https://justjap.com/products/genuine-nissan-engine-oil-level-dipstick-fits-nissan-r34-skyline-c34-stagea-c35-laurel-y34-cedric-gloria-rb25de-t-neo?currency=AUD&srsltid=AfmBOortQXofgmiHVRKuIaiKuygL4k0Ewp68c3isGZk0vvKOJ7Yqf3iB However.... the engraving on the genuine ones say 05002 while mine says AA000. This makes me believe that maybe I have a wrong dipstick? I just want to confirm before I buy a new one. The car is a fresh import from Japan so I don't have details of the previous owner to ask him. Thanks in advance 🙏🏾
    • Sport. I didn’t rebleed it cause I just removed the slave and left connected.    I will change line and slave and see how it goes.
