Grate write up from the event. I have been hanging to read all about it as I refuse to use Facebook and people only seem to talk on there, otherwise you wait months to watch it on DVD.
Do you think that not running any form of bov has caused the turbo failure? I know most people diss like them but a $50 part may prolong a $1500 part. I fitted one after my Garrett shit itself.
One thing that worries me doing a mainland trip is having something go wrong with the car. You can't carry a whole cars with of spares.
Keep it the good work.
well ADGP happened... theres a full write up of the drama's that i had along with pics on my website
http://www.smdrift.com.au/1/post/2012/06/adgp-round-2-wrap-up.html
after the box blew i went thrashing... not a single f**k was given
I can't believe you blew up a 25 box, that mustn't happen every often? also what killed the turbo, just extended high temperatures cook the bearings/rear wheel?
Sucks to have two major things go like that, sounds like you have a blast either way though!
Edited by Rolls
time for an update... first heres some pics and vids from calder.
in car of Ben purtel.. thought it was a good vid cause it really showed the speed of it all and the amount of smoke my car generates haha
another shot with me and Andrew Constatine from Tas... this was during prac session sat morning before my turbo blew. chased him 3 times like this.. first time i tagged his rear bar and you can see my corner light is missing as a result haha
Update time: prepping for WTAC mainly.. that will be the next outing for the car. Diff is getting overhauled and new 4.3 gears. the New motor set up struggles a bit to turn 4.1's with sticky tyres which is why i blew 3rd probably. need an overhauled gearbox and then the motor is probably coming back out for a full check over also. fun times ahead.
i usually run 255/40/17's in Achillies ATR sports or Federal 595. for calder park i tried some of the new Achillies 123s in 265/35/18 pressures usually around the 25/30 psi mark but i actually had to run the 123s higher at 45 psi just to get a decent drift going.
the amount of grip and speed with the 123s is huuuuuuge!
VQ30 would be pretty cool though. But need a lot of attention to intake and exhaust manifolds. They are f**king mess.
Although VQ35 shit would bolt on and strokers, cams choice is abundant. With a really big 6-speed VQ35 gearbox.
It would be indestructable drivetrain. Not sure about the engien though.
You could get a VQ35 gearbox bolted up to RB, Simon. Won't be very difficult and that gearbox is huge. RB or JZ Getrag looks like small kitten near that monster.
Also + for better weight destribution with VQ30.
Edited by robots
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
