yeah that would be awesome haha,m cheers for the heads up on the cam gear i'll check that next time i have to pull the front apart. could well be the case but right now im pretty sure its the diff ratio.
tacho is stock s14 tach. works.. just reads wrong.
i dont think the output of the neo ecu would be strong enought or be putting out the right frequency to run the s14 tacho. the r34 tacho is controled by its own ecu so its not like a conventional tacho.
does the neo loom have the link to hook up a timing light like the rb20 and 26 do? if so id tap into that and run an am tacho. any decent auto electrical place that does gauge work would be able to make the tacho work with a vdo unit.
thanks mate!
im a little peeved atm.... my mate just made 296 rwkw with same turbo, same sized gate, on a s2 R33 rb25 with better power up top, where as my neo comes on earlier and harder. lol im not seriously annoyed but its interesting to compare!
he has no vct and an RB20det inlet cam in place thats the only difference
praccy day run and done.... only lasted 3 laps before issues. IO knew there was going to be heat issues with a high mount turbo so i bought some of that expensive heat sheathing stuff that you slip over your pipes and wiring. not cheap at 60 a meter and what do you know.. it doesnt work too well. The wiring loom for the oxy sensor melted together and shorted out which killed the engine out on the track. lucky was at the start line when it happened. so got back to the pits and sorted out the loom, was worried more was done and thats why it wouldnt start.
once i unplugged the oxy sensor it started. so we thought all was good. repaired the wiring and relocated it well out the way then started it ready to go out again and noticed it was only running on 5 cylns
checked all coil packs first up unplugging them one at a time with the motor running and found number 4 not running. pulled plug and pack out and tested for spark and that was ok... only thing left was fuel and we couldnt test the pulse for injectors at all since no one had a node light. pulled the CAS out with motor off and slowly turned it by hand and counted the injector clicks, only 5 clips per cycle.... hmmmmm
checked wiring loom and went down to the ecu area and and soon as we stuck our head in there could smell that dreaded burnt circuit board smell... pulled it out and opened it up and sure enough.... a burnt transistor and injector driver for number 4 so that put an end to the night :laugh:
over all happy with the car, just need to fix the binding issues at lock and change the diff ratio and it should be sweet as! Jeff thinks he can repair the ecu so fingers crossed!
couple pics from my 3 only laps.
http://www.youtube.com/watch?v=m6O7hVcDme0
Edited by Simon-R32
ey man i just read your thread and watched your vids looks like so much fun im only 16 at the moment but i definley wanna get the no how and skill to drift 1 day looks like sooo much fun.. and loving the s14 looks sexy.
Got my derlin bushes and rear knuckle bearings in now... ended up doing them myself cause a few shops didnt want to touch them (derlins are very hard material and dont go in easy like poly bushes) had to press them in and use a vise to squeeze the knuckle bearings in.
all in all shit loads better then the stock rubber shit so should be good to see how it goes!
Massive thanks to Cazman for devoloping and manufacturing these parts. if your after some they are available through Cazman.
bit of a set back now :laugh:
manifold is off being modded and also we're getting it ceramic coated.. also wanted to do turbing housing so i took that off and what i found was not pretty :D turns out something must have gone through it and turbine is damaged... kinda explains the lack of power also... also glad i caught it now rather then have it explode mid thrash!
take note of the missing chunk!
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
    • Oh man, at least it sounds they've accepted they stuffed up and not put it back on you...could see some confusion if they asked if it had a hardtop or not, and you've answered truthfully but maybe not answering their real question which is what roof did it have from the factory! Glad your keeping it N/A 2.5
    • Nah, I much prefer colour matched Talking about colour matching stuff, the new/used boot lid turned up, all painted up perfectly......aaaannnndddd, it's for a power retractable hard top, not a soft top.....LOL They are now sending a boot to fit a soft top.....,  whilst frustrating, life is like that sometimes, sometimes you just need to dodge, duck, dip, dive and, ummm, dodge.
