google vertical hood....go on i dare ya :wub:
its pretty easy theres two little tabs on the hindge which bottom out at full extension... i used a hammer and chisel to bend these back. some ppl cut them off but the beauty of bending them back is that they still provide friction when u go past the normal point.
some updates!
I got some clear headlight covers from http://www.2-up.com.au/ and the quality is awesome.. got to work on the old lights getting the lenses off and that was fun thats for sure. put the covers on and they fit perfect. sealed them up and let them set then chucked them on today along with new front bar.
looks a lot better now thats for sure just gotta get some corner lights!
got a new Gate as well as some poncams. will be putting them in and then hitting up winton very soon.
heres some pics.
pretty cool build.
I have the same sort of setup. s14 series 1, r33 rb25 with 3037s, makes 296rwhp on 15psi. hope to see this at winton for drift attack!
Yeah I'll be there mate. Just got retune with poncams and now makes 330 rwkw and near 600 nm torque!!! Goes well lol
full boost at 3400 rpm. .63 rear housing using 100 ron fuel. and yeah the poncams retain the VCT.. is sweet!
hey simon. i would have thought you would have the .81 housing but guessing the .63 is what helps with response? im just in the process of getting a new turbo setup. manifold and gate are sorted but im trying to select the best turbo combination to keep good response.
at the moment we have decided on a GT3076R with the serge compressor housing and a .63 rear. but im am concerned that it wont flow enough.
depends on what your end power goals are... the .63 does 300 rwkw no worries at all.. has all the responce in the world. i love it! dont need to rev the shit out of it to get power u can just ride the fat torque band in the midrange.
    • It still combines inches with mm, especially when you have .5 inches involved, and mm and inches that can go in either direction. This would give a clear idea on both sides of the rim, right away, with no arithmetic. Even better if somebody gives you the dimensions of the arch of multiple cars. i.e GTR may be 125mm, a A80 Supra may be 117mm, or something along those lines. Yes, you can 'know' that going from a 10in rim to a 10.5in rim with the same offset moves both sides about 6mm, but you still have to 'know' that and do the math. Often it's combined. People are going from 9.5 +27 to 10.5 +15. You may do the math to know it, but if it was going from (I had to go look it up to be sure) 241mm/2 - 27 - 93.5mm from the center line to (more math) 266/2 - 15 (118mm) from the center line. Versus 93mm vs 118mm. It's right there. If you know you have a GTT with 100mm guards you can see right away that one is close to flush and the other absolutely won't work. And when someone says "Oh the GTR is 120mm" suddenly you see that the 10.5 +15 is about perfect. (or you go and buy rims with approximately 118mm outward guard space) I think it's safe to say that given one of the most common questions in all modified cars is "How do offsets work" and "How do I know if wheels will fit on my car" that this would be much simpler... Of course, nothing will really change and nobody is going to remanufacture wheels and ditch inches and offset based on this conversation :p We'll all go "18x9+30 will line up pretty close to the guards for a R34 GTT (84mm)" but 'pretty close' is still not really defined (it is now!) and if you really care you still have go measure. Yes it depends on camber and height and dynamic movement, but so do all wheels no matter what you measure it for.
    • But offsets are simple numbers. 8" wheel? Call it 200mm, near enough. +35 offset? OK, so that means the hub face is that far out from the wheel centreline. Which is 2s of mental arithmetic to get to 65mm to outer edge and 135mm to inner. It's hardly any more effort for any other wheel width or offset. As I said, I just close my eyes and can see a picture of the wheel when given the width and offset. That wouldn't help me trust that a marginal fitment would actually go in and clear everything, any more than the supposedly simple numbers you're talking about. I dunno. Maybe I just automatically do numbers.
    • Sure! But you at least have simple numbers instead of 8.5 inches +/mm, relative to your current rims you do maths with as well, and/or compare with OEM diameter, which you also need to know/research/confirm..
    • Uniclutch install vid, RB Track edition.   Highlight reel is very drive able, not noisy but still heavy with the clutch master he has.
