360 rwkw!!!!!!!!!!!!!!!!!!!!!
fark the car is insane now... running 50/50 mix of fuel and its just nuts. can run an extra 15 degrees timing at full load and the low down torque and response is awesome!
power was made on 16 psi too.. where as before it was running 19-20 psi and made less power.
if you dont mind me asking. how is it that your GT30 is flowing so much power at 16psi. A GT35 would be very lucky to make that much power
on 16psi. Am i missing something? also the torque is alot lower then i would expect for that sort of power.
no gains over straight e85.. just less reliance on larger fuel sys and moisture absorbing.
either way... car is awesome... BAKES tyres hard now hahaha.
came 1st in state comp today :banana:
oh very good on the G1 win. about time youve been around for ages. (thats a good thing) i was watching zero traction DVD only a few days ago. id never seen it. plenty of you in your old ceffy. and i think ive got the dvd that had you drving a eight six back in the full lock days.
so how many years have you ben competing? whats been the best car and best highlight?
hmmmm... about 7-8 years now...shiiiit thats too long and too much cash haha.
i have a fond spot for my blue NA 86... nothing liking holding it pinned flaty out at 9000 rpm and just throwing it in hard... had 12 deg neg camber front with mega stiff susp... wasnt ultra competitive but damn it was fun!
best highlight would be battling Shinji Minowa in my 32 4 door at dec 07 drift nats at calder park for 1st and 2nd place (i came 2nd) to drive against a jap driver and have a re run and only just lose and yet learn so much about driving was an amazing experiance.. i also took hom 6K prize money that was mindblowing.
this s14 has been a mixed bunch of emotions.... enjoyable car but damn its very hard to pull off consitant runs due to it being so knife edge
came 1st in state comp today :ermm:
well done great result. :banana:
if you decide to go with bigger injectors to run full E85. Ill give you a link to some 1000cc bosch injectors that work a treat. only $480 delivered.
your red 4 door when it had the XD9s on it was its pinnacle for me. but im a 32 fan. i still cant belive that i didnt buy that 4 door back in the day. i had 2 chances to.
    • But it's much better to use a freedom unit that has four different possible meanings...
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
