did a search, but came up empty
what's the size of a standard battery in a C34 S2 Stag?
i'm looking to get my hands on an Optima D34M, which is 10"x7"x 8" (254x175x200), LxWxH
is 200mm going to be too tall, and hence foul on the bonnet? might need a bit more than 200mm, after adding terminals etc.
thanks all :cool:
https://www.sau.com.au/forums/topic/291012-c34-s2-battery-size/
mine came with a panasonic 220 or 250 cca piece on crap, i drained it in 3mins leaving headlights on!
looked like it would fit in a toddlers motorised car/motorbike that you buy from toys r us.
just poppin out to the garage to take a pic of the beast battery i put in and grab some measurements.
650cca from memory, about the same size you'd put in a 4wd or small truck :(
brb
It's an exide din 66
27.5cm long
17cm wide
18cm tall
i recon you could go:
- 18cm wide...tight fit.
- 28-29 cm long, but it will get close to the radiator, hose, inlet manifold and pickup more engine heat
which would be detrimental to battery life.
This is what i was worried about, but 2.5 years and it's still fine, no leakage/sweating.
- 20cm tall looks like it's ok and wont foul the bonnet. that would include terminal posts. (overall height).
Autobarn staff are normally very helpful and will help with a test fitment, chat to them.
ps. 610cca, as per the pic... and i've left lights on for 2hrs before at work and no sign of drain with this battery.
Edited by Stagea_Neo
As above mine came with a useless piece of ""it" Lasted about three weeks.
Got a Supercharge EG, 600 cca, 230 x 160 wide x 185 high excluding terminals. Never missed a beat and run 4 amp cooler all day no worries. Actually apart from a tie rod end it is the only thing I have HAD to replace in 31/2 years.
I would not recomend you put a optima in .
I work for a battery sales company and the optima are way too over priced and they have a warranty but to actualy use it is like pulling teeth.
if you need a battery with high cca out put but still an amp hour rating i would suggest you run a dry power 12v 26ah wich is what i have in my car.
they are lighter and smaller then a optima and still have good cca ( 600 cca @ 5sec) and good Ah ( 26amps @ 20min).
you should be able to get one of these from any battery shop , if they dont have a dry power you can use any SLA ( sealed lead acid) battery that is rated for cycle use and not stand by.
if you want any more info just ask.
how much are the dry power batteries?
the D34M is sealed, deep cycle, 55ah and 750cca
can get one for $270 too, which is quite reasonable considering the RRP of $475
  • 5 months later...
Series II battery went dead the other day so I thought I'd let you reap the rewards of my research..
OE = 80D26R (cold weather spec.) (±260mm X ±172mm X ±225mm incl. posts) listed in no particular order..
Brand | Model | CCA| RC | Price | Origin
Century | NS70X | 545 | 130 | $225 | Australia
Exide | N50ZZMF | 600 | 130 | $??? | Australia?
Bosch | 90D26R | 620 | 140 | $215 | Unknown
Bosch | 110D26R | 680 | 160 | $lots | Unknown
Supercharge | MF80D26R | 670 | 140 | $135 | Philipines
ALCO AtlasBX | 90D26R | 630 | 130 | $150 | Korea
ACDelco | S80D26R | 600 | 130 | $??? | Korea
Enjoy!
    • GTSboy, thank you again. i’ve been reading all the other SAU RB25 vacuum line threads and you have the utmost patience for people asking “where do my vacuum lines go”. it’s appreciated. i did also enlist a few other RB guys local to me.  i would like to run 5 to 4. turbo pressure side to wastegate actuator. i would like to run 3 to 1. power steering air valve line to intercooler outlet. (this is how it was previously). i was told 2 is the bleed port for the boost solenoid - which i’m not running - so should be capped.   anyone see any problems with that?
    • So yes. All of them. Something like 98% of all fuel in the USA has 10% ethanol: https://afdc.energy.gov/fuels/ethanol-fuel-basics It's labelled as like, AKI, 87, 91, 93 with an E10 or E5 or E15 label on the pump. At a certain point, it's not just "E10" instead of 91. It is 91, 95, 98, and all of them have 10% Ethanol in them. You can also get E85 and E30 which is why you do see some people rolling around with E30 tunes in them.
    • Thanks for the response. This is an 04 EP3 Type R. JDM spec. Fairly certain they're just basic BC racing coils. I do plan to keep as the ride quality on stock I've been told is pretty meh given Sydney roads. If I were to go down that avenue, does NSW require them to be a certain spec (close to original) etc?
    • Should have asked what is the car?
    • I've had two super conflicting experiences with blue slips. My 30 year old E39 waltzed through with no issues but my brother in law was knocked back on 12 y/o 3 series due to wiper blades and some cracking in a control arm bush.  What kind of coil overs? Do you want to keep them after?  If it was me I'd get some dirt cheap shocks and springs from eBay or scumtree. Not ideal but will get you over the line and might even be less than $1k.
