did a search, but came up empty
what's the size of a standard battery in a C34 S2 Stag?
i'm looking to get my hands on an Optima D34M, which is 10"x7"x 8" (254x175x200), LxWxH
is 200mm going to be too tall, and hence foul on the bonnet? might need a bit more than 200mm, after adding terminals etc.
thanks all :cool:
https://www.sau.com.au/forums/topic/291012-c34-s2-battery-size/
mine came with a panasonic 220 or 250 cca piece on crap, i drained it in 3mins leaving headlights on!
looked like it would fit in a toddlers motorised car/motorbike that you buy from toys r us.
just poppin out to the garage to take a pic of the beast battery i put in and grab some measurements.
650cca from memory, about the same size you'd put in a 4wd or small truck :(
brb
It's an exide din 66
27.5cm long
17cm wide
18cm tall
i recon you could go:
- 18cm wide...tight fit.
- 28-29 cm long, but it will get close to the radiator, hose, inlet manifold and pickup more engine heat
which would be detrimental to battery life.
This is what i was worried about, but 2.5 years and it's still fine, no leakage/sweating.
- 20cm tall looks like it's ok and wont foul the bonnet. that would include terminal posts. (overall height).
Autobarn staff are normally very helpful and will help with a test fitment, chat to them.
ps. 610cca, as per the pic... and i've left lights on for 2hrs before at work and no sign of drain with this battery.
Edited by Stagea_Neo
As above mine came with a useless piece of ""it" Lasted about three weeks.
Got a Supercharge EG, 600 cca, 230 x 160 wide x 185 high excluding terminals. Never missed a beat and run 4 amp cooler all day no worries. Actually apart from a tie rod end it is the only thing I have HAD to replace in 31/2 years.
I would not recomend you put a optima in .
I work for a battery sales company and the optima are way too over priced and they have a warranty but to actualy use it is like pulling teeth.
if you need a battery with high cca out put but still an amp hour rating i would suggest you run a dry power 12v 26ah wich is what i have in my car.
they are lighter and smaller then a optima and still have good cca ( 600 cca @ 5sec) and good Ah ( 26amps @ 20min).
you should be able to get one of these from any battery shop , if they dont have a dry power you can use any SLA ( sealed lead acid) battery that is rated for cycle use and not stand by.
if you want any more info just ask.
how much are the dry power batteries?
the D34M is sealed, deep cycle, 55ah and 750cca
can get one for $270 too, which is quite reasonable considering the RRP of $475
  • 5 months later...
Series II battery went dead the other day so I thought I'd let you reap the rewards of my research..
OE = 80D26R (cold weather spec.) (±260mm X ±172mm X ±225mm incl. posts) listed in no particular order..
Brand | Model | CCA| RC | Price | Origin
Century | NS70X | 545 | 130 | $225 | Australia
Exide | N50ZZMF | 600 | 130 | $??? | Australia?
Bosch | 90D26R | 620 | 140 | $215 | Unknown
Bosch | 110D26R | 680 | 160 | $lots | Unknown
Supercharge | MF80D26R | 670 | 140 | $135 | Philipines
ALCO AtlasBX | 90D26R | 630 | 130 | $150 | Korea
ACDelco | S80D26R | 600 | 130 | $??? | Korea
Enjoy!
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
    • ...oops. forgot the TCU end...
    • No I got mine from a friend that had fabricated one … but I had to fit it to my setup which was a hks turbo setup. His was a Garrett -7. So one of my turbos was not a flange for one side … then I had a leak in the welds I had to find a weld shut … in the end the setup was decent priced but I spent a lot to get it fitted. A couple companies I checked would make it but you’re talking 7-9k aud with titanium. No joke mine was 6-7k even second hand after I had to fit it in Hong Kong … labour is expensive here.
    • I'd just like to restate that I don't think anyone here is actually hating I recently sold a car part to a guy who was building a forged auto R34, with MV stall and aiming at ~450kw. I told him that I'm him, from the future and to stop after it explodes once. I told him I knew he won't listen the first time, and that's fine. But if my predictions do come true - Change direction faster than I did. I also said it's probably no coincidence that the dyno plot of a reliable turbo engine starts to look a lot like a N/A motor. :p
    • Got just the wing painted and fitted up to the existing boot. Big visual change and about time after having a GTR wing sitting in the shed since 2018 Headed up to Mallala with a quick obligatory stop in at Boliver OTR Oil control mods seems to have worked. I checked the catch can after session 1 and there was a dribble of water/e85 with barely any oil in it. After session 2 and 3 there was almost nothing and I stopped checking after that. so either great success or catastrophic failure/block of the external breather The GTR wing made a noticeable difference in the 160-185km/h sweepers. It was a very hot day for the cars at over 33C but the previously done cooling upgrade/ducting/water sprayers meant I never saw over 60C intake, 105C water and 100C oil and temps would drop back down very quickly once I shut it down. AD09's are a decent tyre but certainly and expectedly a step down when compared the the CR-S/AR-1 I have had on the car for years of track days. The handling characteristics of my car which I often describe using the Tony Hawks Pro Skater balance mechanic where either side of the center is understeer/oversteer was much more pronounced with no "green/safe" zone in the middle. However, imo it steers well/easily during oversteer largely thanks to the custom ACOSTAL front end. Enjoy a loose lap POV with my mate giggling away as a passenger.   Group photo for Peer Pressure Racing made it back home and gave it a wash Overall a great success compared to my previous two track days where i cooked the Starlets motor and blew up the new diff in the R32
