so i ran the car down today to have my new dump pipe and screamer made up... i have a high mont t04e with a hypergate 45mm external gate...ebc ( greddy profec b ) i had a jjr external gate on it before and since the change i cant get it to boost over 5 psi..the gate just opens no matter what ... i tried playin with the boost controller up the boost n that...still 5-6 psi ( which i assume is the ext gates spring ) now the ebc was installed all perfectly cause i have been running 16 psi with the other ext gate .... only changes i have made is now i have 2 vcuum lines goin to the gate ( the old one i only had one,comin from the solenoid) but now i have one from the plenum aswell... and that vacuum source used to go on my microtech ecu but now has changed to a power fc... i am completely stumped to y the boost controller is basically in active .. it still reads the boost and everything on the profec b... any ideas??..could it be the vacuum lines??
any help would be greattt :(:D
alex
    • The car remains in paint jail. I am now pretty convinced that the whole "RB25 Airboxes are kinda limiting to ~300kw" could be a thing. Also saw a good video from Engine Masters: (Sorry for FB link) (https://www.facebook.com/watch/?ref=search&v=761771519471924&external_log_id=c10bcbb6-2c39-4ff3-9240-287e9921fde6&q=Cold Air Considerations) Where they tested Pod Filter sizes and kept adding bends to a LS3 on an Engine Dyno to find if bends caused power loss. It's a good video worth watching - They did lose ~25hp from making an intake which had 3x90's and a 120 degree. They only lost maybe 1hp with a basic 90. I feel that by sealing up my airbox I have: 1) Created the same restriction a stock airbox would have. 2) Created a very convoluted set of intake 'pipes' by forcing all the air through the ducts. So I am pretty confident I'll be going full circle and have a huge hot air intake pod and actually see a benefit. The air does *not* stay hot once it gets flowing, aided by the ducts, and the pod can then pull air from anywhere. All the posts of yore talk about the stock airbox costing 10-15kw at 300kw+ but you know what? I f**king would very much like that 10-15kw and I remember my own pod filter in engine bay experiences. Turns out the GTT Reo and Headlight brackets really don't allow you to mount GTR items, no matter what the internet says. Various brackets have had to be made up to actually make it fit right for the front bar. Also some idiot mounted a 3L Accusump right where the bumper wants to go, so that has had to be 'relocated' To where, I am still not sure, but it's supposedly mounted in the pictures and I can't see it.
    • Sounds like the oil pressure light is wired into the oil temp sensor... As it warms up, resistance on temp sensor reduces, hence more current can flow and the dash light gets brighter.
    • Got the front subframe and suspension in.
    • If it's cold in summer, then no issue. If it's cutting out every few seconds and you're not reaching your target temp, then there's an issue. One could be the pressure switch and the other issue could be the temp probe inside the evaporator.
