My car has been running very hot for a while in between half and 3/4, i just recently got my radiator flushed and was told it was 85% blocked :flamed:
They also informed me at the time i needed a welsh plug replaced.
ANYWAY The car still seems to be running hot its not dropping any water now though.
Also how easy is to do a head gasket on a r32 could this be possible? i have checked and so far found no evidence.
https://www.sau.com.au/forums/topic/29104-im-worried/
i'd buy a second hand or reco'd radiator and get the welsh plug fixed...
you can warp the gasket.... but i dont think your car is getting hot enough to do that.... but act on it asap cause the longer you leave it the more damage that can happen later... and the more you "get used to it"
Happened to my dad.... he found out the hard way ....Boom!!!!
$$$$$$ later reco'd engine. Goes better now!! (it was a Jackaroo)
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-598057
yeah Pekatu thats normal
It should always stay at 1/2 no matter what. Any more and your in trouble!! I learnt this the hard way, i blew the head gasket on my last car and it cost me $$$
The stock gauge is fairly accurate, but an aftermarket one it will go up or down +/- a few degree's depending if you thrash it or just cruising...
Always keep coolent/water in your boot and if you ever see the guage go over 1/2 pull over before it gets too hot and see where a leak may be. Then top up your radiator and cruise your car to home/mechanics
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-598620
You might want to take a look at ur thermostat. In other words buy a new one cause there not expensive. They have a tendancy to jam half open wich will cause your car to run hot. If it was the head gasket you would be using heaps more fuel that u usually do and there would be a lot of black smoke out the exhaust from richness. Worth a thought.
Cheers
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-599018
How does a blown head gasket cause the car to use more fuel?
It will often allow water to get into the combustion chambers, giving white smoke out the exhaust, or may let oil in, with a bluer smoke out the exhaust.
Try the thermostat. If that doesnt work, do the waterpump, and make sure you bleed the system of air, there are bleed bolts (10mm head on my R31) on the intake plenum/manifold.
Good luck.
https://www.sau.com.au/forums/topic/29104-im-worried/#findComment-600072
    • It's the adhesive holding the ceramic wheel to the shaft the fails on 90% of them.
    • Foreign debris, physical shock, boost leak, could be anything honestly. The danger in taking all the timing out of a tune/hitting the R&R corner is that even if the engine doesn't detonate your turbo is taking a lot of abuse from high EGT. Also, even if nothing goes wrong it is a journal bearing that is spinning at 100k RPM on boost. Eventually it goes through enough cold start/pressure cycles to wear it out.
    • I kinda accidentally saw this, and was interested, but It actually seems to replaces the whole center computer, using the existing screen and buttons. AND it may only be for a G37 and not compatible with a Japanese 370. So its not for me, but someone else may be interested to look into it. Its about $680USD. If I am understanding it right, it basically replaces/installs and android pc that integrates with the existing screen. But I could be wrong. https://gromaudio.com/vline/ The video I first saw was the following, with very little and unclear details.     Even if your not interested in the system, the video on their site was pretty comforting in showing how simple the whole centre comes out
    • hfygrte52 what side you looking for? Do you care what color car it's off? Found a white LH side on here: https://skylinespares.com.au/product/nissan-skyline-r33-coupe-rear-tail-light/   Aussie parts place but will ship to USA. Maybe get it before there's a tarrif on 25yo shit box parts
    • I’m with Shannon’s for all 5 of our cars. Agreed values seem fair, premium price is okay. ($210 ish a month, all comprehensive).  Have claimed once with them for a not at fault claim with another car where my car had no damage. Was one call after the incident and an email after. Deemed not at fault so premium didn’t go up either.    I have called up and spoken with people who are not familiar with certain cars and didn’t agree with me on value or let their personal vehicle preferences effect the call. But called back later and got someone else who was more agreeable.
