I have a few noises that I am trying to sort out before I bolt on some power. I am currently in Darwin and it is a major struggle to find someone that is familiar with transmissions.
PROBLEM 1
When in neutral at idle there is a rattle from gearbox/clutch area.
Noise disappears when clutch is engaged (pushed in)
Dont notice rattle when driving, however this could be due to engine/exhaust noise.
Clutch is not standard, heavier duty however unsure as to what exactly (bought it with it in car already)
Noticed problem after service (Oil Change)
PROBLEM 2
In all gears (loudest in 1st and 2nd) there is a whine on acceleration and deceleration.
Whine increases and decreases in pitch with engine RPM.
Loudness doesnt seem to change.
Gearbox feels tight and haven't had any gear changing issues.
QUESTIONS
Does any know the probable cause of either problem and wether they are related or not?
Anyone experienced similar problem before, if so please shed some light.
I appreciate any advice/experience posted
Cheers
https://www.sau.com.au/forums/topic/291073-gearbox-or-clutch-problem/
When you say 'service' are you talking about engine or gearbox service?
It's most likely gearbox noise going off your description but it would really depend on a few other things and how
loud it is.
I would say you should start by changing the oil in the box. Use something like an 80w140 Castrol if you can get it. That should silence it. If you were referring to a gearbox service, then the workshop may not have used the correct oil.
Just worn gearbox bearings through the box. Sounds like the oil hasn't been changed in a long time, sludging the old oil which probably masked the sound of worn bearings throughout. Changing the oil for fresh brings out these noises. You can silence it with a different oil but the only way to properly fix it is to recondition your gearbox.
Thanks, I've had the same issue since I bought my car, had the diff re-built, changed oil twice now, still whines, I guess it will need a recondition at some point :P
Problem 1: Had exact same noise in my R32 & R33 boxes. Would bet it is the cluster-shaft bearing located in the seperator plate. cop to get to as whole gearset needs to be removed from shaft but if you can do the work yourself its only like a $40 bearing
Problem 2: Have you turned your stereo off? haha. Im not hanging shit, just my mate complained to me for months about a high-pitched noise in his GTR, increasing with revs. Finally took it for a test-drive for him & worked out it was from his amplifier wiring.
Anyway good luck
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
