hey all just need some quick rb25 info as im new to them and dont know much about
them have always had rb30et's ok so first i have just bought a vl with a 1996 r33 s2 rb25
conversion done in it mods are 3 inch exhaust and cooler using standard r33 ecu
ok well it was only running standard boost 7psi but i just bought a boost tee and put
it up to 11-12psi now i know they only have a ceramic rear wheel so how much boost am
i safe to run ?? and how much power have ppl gotten out of just few simple mods like mine
and whats acheivable with standard turbo dont wanna upgrade just yet but yer just really
wanna know the boost one before i go driving it to much on 12psi any info is muchly appreciated
thank you all RBJ37
IIRC the series 2 turbos can handle a bit more boost.
Dunno where, but I definitely saw that somewhere.
Still wouldn't go past 12 pound...
With all that, you should be looking at about 180-220rwkw depending on the tune.
If i were you, id be getting a tune, so you can really enjoy the benefits of the increased boost.
[EDIT] my mate has a RB25 (series 2) in his patrol, and runs 12psi daily, no issues. He was at 15psi for a while, and that poor little turbo is still going fine...
Edited by turbo x-trail
thanks heaps for the info but how can you get a tune with a standard ecu ?? what just timing and what not
im not to sure with these 25's and there comps i only know rb30et's as thats all i have ever used i know you cant
do much with a standard vl turbo ecu are 25 comps much different ?? i got nothing to tune only standard ecu ??
My advice is leave the timing alone(15).
Save up and get a power FC or get a nistune. Might want to turn the boost down to 9-10 if youre going to be taking her to the track.
i was actually just thinking about goin to see my good mate rick at efi performance and was thinking
bout goin with a nistune and maybe using a z32 airflow meter as i have heard they are the best to use
and will support upto about 500hp ?? and for about 950 fitted and tuned the nistune is best bang for the
buck i reckon what is everyones thoughts on even just using maybe and safc and maybe e boost2 or
something was thinking maybe just goin that way as i would be happy with 200rwkw for the mean time
till i upgrade to 35/40 and all the rest of the goodies :) and would 11 psi be ok for the street with standard
turbs thats what it is on atm cant hear any pinging or anything of the sort so think should be ok maybe till
i get a power run and afr to make sure everything is ok.........
12psi is fine. aslong as base timing is set properly and everythings working as it should then it wont knock on the standard ecu, way too much fuel and not enough timing. for nistune on a 25 you need to use a r32 or z32 ecu, z32 allows you to keep vct but requires a few wires to be changed around.
Running 12 psi on your stock turbo is fine wouldnt go over though. With your current mods... i know with a PFC stock turbo you'l be achievable of doing 180-200kws. With stock ECU maybe 160-170's range.
well i have set on just 11psi so wont push it anymore then that might go for a highflow very soon as my mate
works for mtq here in brisbane and builds turbos all day haha get myself a brand new highflow for about $400 :)
pretty sure base timing should be ok seems to run fine just not as fast as i would thought it to be i think there
might be another little problem as if you put your foot flat to the floor it doesnt really wanna go anywhere but if
you just ease it on slowly it starts moving really need to get a tune and check timing anyway how do i do that
on a rb25 as they are a lil diff to rb30's ??
and does anyone have a z32 comp they wanna sell me so i can do a nistune comp
if anyone has one let me know price and shizz i can get one for 250 but just seeing
what else i can get cheaper thanks ppls
you dont need a Z32 afm for 200 rwkw and stock turbo, just nistune the board with stock afm and it will be sweet
yer i know that i sed has anyone got a z32 ecu for sale and i have been told no point doing the
z32 airflow meter till i do injectors so all is good just need ecu and i will use the standard 3 pin afm
till i upgrade turbo and injectors :P
oh sorry i read wrong.
Personally i would just remap a 32 ecu, disregard the lack of VCT as once the ecu is tuned the loss of VCT is not at all noticable
i have heard that you can notice it a lil bit in the midrange ??
depends on the tuner.
When mine was tuned, it made more power everywhere in the rev range, so a loss of midrange was not noticed or even evident at all when compared to the stock map.
that said ive driven some set ups with utterly shit tunes on them and they feel like a dog to drive down low but go hard up top. thats because theres plenty of tuners out there who are shit at anything but focusing on WOT maps.
hmm interesting well thats really good to know that its only in the tune :P quite funny how the vct doesnt have
any affect really if the tune is altered haha hmm anyways i will see how i go wen the time comes to put the nistune
in wich will probably be in the next 3 to 4 weeks :ermm:
and a graph of what happens when you run too much boost with a standard ecu, on a s1 anyway. vtec yo
http://i224.photobucket.com/albums/dd251/J...17052008009.jpg
as for not going anywhere, is it blowing out spark?
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
