Hey guys,
Read this forum for ages but hardly post.
I have recently had an issue with my R33 GTST skyline (minimal mods - FMIS, exhaust, BOV and Kitted).
First thing my coilpacks started fkn up with the misfiring - my fault - vented carbon bonnet out in the rain (forgot to cover it) - took it to a mechanic who put some coilpacks to fix that up.
The problem has come back and after it started i stopped driving the car.
I tried to start it up again the other day to move it and to my amazement - it didn't start. :)
Symptoms;
* all lights and checks in ACC are fine - nothing abnormal except my deck no longer starts (it used to before).
* When i try to crank it over - all the lights cut out and nothing happens.
* WHen i turn it all off and take the key out my turbo timer kicks in (normal) although it is followed by a horrible flicking/clicking sound coming from the front - WTF!!!
i have no clue as to what it is.
Wanting to know if anyone else has come across this?
Much appreciated.
https://www.sau.com.au/forums/topic/291154-r33-gtst-95-model-issue/
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
