Harder than I thought to find info on this, but basically I need to get just the engine out of my R33 so the rest can be towed away *sob* by the guy who will wreck it himself
Just looking for help from anyone that has done this before, and hints & tips that I can put to use. I want to try & do as much/what I can before it goes off somewhere else to get the engine off, but need help on the technical side of things as it's something I've never done before. I'm not afraid of getting my hands dirty but want to try doing what I can at home first.
Got as far as draining the fluids, taking out the radiator, injectors are out & most of the various lines & hoses from the top part at the moment. FYI the gearbox, turbo, everything will stay with the car, but I also need to know if they have to be taken off/out separately anyway. I've linked a couple of pics at the bottom of this post to show the type of engine bay I'm working with, which is where these questions might be easier to answer:
For the exhaust manifold, I've got 8/10 of the bolts off, the other 2 I'm struggling to see how they got on in the first place, but I think they might be possible to get to from underneath (which I can't try yet). If I get those off I can then remove that with the turbo & where the gate goes back into the exhaust & keep it aside. Or would it be better to remove the turbo & gate along with the engine & take it all off when it is out?
On the other side where I'm finding it a bit trickier, what need to come off & what doesn't? Do I stand much of a chance getting the intake manifold off while the engine is still in the car? Pretty much, what else can I get to from above that needs to be taken off or is easy to take off before the engine is out??
Leaving the air con part to someone who knows how to not poison themselves :D But yeah any other help would be much appreciated, I'm hopeful to get as much done as I can & try to get someone to do a cashy job for me on Saturday on getting the engine out so it can be picked up as I'm supposed to be flying up north the following weekend, and midweek isn't an option for pick up. Thanks!!
Nathan
https://www.sau.com.au/forums/topic/291165-removing-rb25/
leave your manifolds on, remove all air pipes, remove exhaust from the dump, disconnect heater hoses, disconnect fuel system, remove PS pump and set aside in the engine bay (or remove PS reservoir as well), leave gearbox on, disconnect rear tailshaft from diff and then the centre bearing and then slide out of the gearbox, remove clutch slave, follow your electrical lines and DC what you have to (cant remember..), remove clutch fan and rad (you've already done this, hurrah), probably more things but that's what I can recall directly.
shoot us a pic of your current engine bay with what you've removed.
do you have an engine crane?
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4869307
Cheers for that Chris, I'll go grab a couple of pics & put them up later, doing what I can before it gets too dark today! A fair bit of that seems better off to do from underneath but I'll try to get onto the rest soon!
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4869428
Couple of pics attached. Didn't have the chance to disconnect the power steering pump this afternoon, spent most of it looking for a spanner I managed to lose just underneath the intake manifold, heard it hit metal but didn't make it's way to the ground, and still can't find it :rant: No idea what gap it's managed to fall into lol, no matter what angles I shine the led in I can't see it, so I'll just leave it until the engine comes out haha
For what I can see at the moment its just that & most of the lines near the firewall to disconnect. Got a mate who is a mechanic who I can hopefully get over to my place this weekend to help me a bit (but it is powercruise weekend over here I was reminded today so it might have to wait until next week). I don't have an engine crane but can get one to use to do it, it's just a matter of seeing if it's possible to get it all done in my backyard, or otherwise have to tow the car somewhere else to then get the motor out....
Thanks again
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4869709
hey mate
yep, its all possible in your backyard. if you know what you're doing, and have the right tools, you can get an engine out in under an hour. I take around half a day. first time takes considerably longer - you're learning and fixing other things up along the way etc.
there isnt too much you have to do under the car. theres the tailshaft, the clutch slave, gearbox mounts..
looks like you've made a decent start, you still need to disconnect your brake booster, catch can, heater pipes by the looks, aircon, exhaust (dont forget 02 sensor first)
you're pretty close.
when lifting it out, try to make the chain / strap as short as you can to the engine, so you can lift it higher, makes getting the tail end of the gearbox over the rad support easier. also, your gearbox is going to leak everywhere, drain it first or plug up the output hole bit.
so undo the gearbox mounts while have a trolley jack supporting it, and undo the engine mounts, and then just lift it up out of there! take it very slowly in case you forget anything, and remember you can always lower it down again!!
and a big lever will come in handy
edit. your spanner is probably around the crossmember / engine mount sort of area. and powercruise, yah, my mates went to that too (i'm in mandurah)
Edited by turael
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4870464
also look at taking the bonnet off the car, don't have to worry about hitting it with the engine crane and it gives you more room, but if the gearbox is going with the car you can undo the engine mounts and the gearbox mount (with a jack under the gearbox) tilt the engine back and undo the top two bolts from the bell housing to the engine, do the gearbox mounts back up and then remove the rest of the bolts that makes it much easier to get the engine out without taking the gearbox with it as you can virtually lift it straight up out of the engine bay
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4870680
yes first up, put the car where you'll have room to manouver a crane around in front of it, then put the front on stands and take the bonnet off. makes life SO much easier.
another tip. its always easy to remove stuff like injectors OUT the car rather then while in the car, si i would have left them well alone until the motor was out and sitting on the ground.
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4871046
hmm for my 180 i removed the whole fuel rail... so out came the injectors and everything... just swiveled that around and left it all attached, didnt have to de-pressurise the fuel system that way. Not too sure if it that's simple for rb25's though.
and yeah, take your bonnet off, will make life much easier.
if you're going to take the gearbox out with the motor (which is pretty simple, but you might want to see if you can unbolt it from the engine and leave it in the car instead of having to put it back in anyway?), make sure it doesnt hit your cross member as you lower it and drag the engine forward. you'll crush your PS lines.
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4872873
Well over this weekend I didn't get as much done as I wanted to, but from what I can see it should be all smooth from here. All the hoses are now off & the loom is out of the way on the windscreen. The only problem with that is there are some wires still plugged in that I can't really get to, but I guess I'll just have to get at them as it's coming out bit by bit. And yeah i will be removing the bonnet, I just won't be until it's time for it to come out as I've still had to keep it all covered, but yeah shouldn't have taken off the injector rails but I only learnt that after it was off :D
Where my car sits in my backyard there is heaps of room at the front of it, so I havent got any dramas with moving an engine crane around :D At the moment I'm really hoping to get it out Tuesday or Wednesday night, that way I'll have enough time to get stuff off the engine that's going with the car. Tomorrow it's going on stands where I can then get underneath properly & have a play around, home stretch now though :D
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4874444
you'll find that the wires you cant get to might be easier to get to from under the car?
also, on the alternator side of the loom, you can leave that on the motor and just seperate it from the fusebox at its various connections, this will save you some skinned knuckles
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4874648
Just another little update, got the car up on stands tonight after work. Took all the bolts out of the gearbox except 2 I couldn't get to, have to get one of those wobbly connector things to get to them but I think it should be fine. That is the one at the very top & the one on the passenger side to that. Tailshaft is out of the gearbox, couldn't get the engine mounts just yet because my sockets aren't long enough to go onto the nut before it's hitting the bolt. Same with the exhaust manifold....size matters :) Haha but those will be easy enough
Looks like I'm on track for having it out in the next couple of days, depending on what I can manage to get done at night after I get home from work. Pick-up might be delayed until next weekend anyway so I might not have to rush it but I'd still like to get it done at once & not have to wait. I'd love to be able to have it done in around an hour like mentioned lol, but it's a good experience to do something like this...I just won't be rushing to do it again anytime soon!
Cheers, Nathan :)
I'm the first to admit I straight out SUCK when it comes to electrics, but I'm sure even I can trace back a few wires & do it that way :P It's only a few at most anyway thankfully
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4876712
yo, leave the manifolds connected to the engine. you should take the engine out all in 1 piece! its easier. certain things you take off the engine, such as piping, cooling, power steering.
once its all ready, chain it up and lift it out bit by bit very slowly incase you have missed some wires or something (an engine crane will not forgive), you will be surprised how quickly it comes out.
and for the engine mounts, try a spanner maybe :P
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4877054
Those 2 bolts I was talking about were the ones mentioned in Titans post above....brain fail!! Do as he mentioned it should be ok. I did try a spanner lol, didn't happen for me cos they seem to be on farkin tight :thumbsup: Yeah the manifolds will be staying on until I get it out, I just meant from the dump pipe
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4878703
Thought I may as well update this, finally took the engine out on Saturday because I wanted to do it in the daytime just in case, but didn't have too much of a problem with it, everything important was already done beforehand. Just myself & my mums boyfriend who helped me out. Went block & tackle style from the patio roof getting it out, worked out to be perfect height for it. There was only a couple of wires to disconnect but as we got it up a bit more they were easier to get to. Would have been easier to take the gearbox out with it as mentioned, but it was possible to leave it in so all good as it was going with the car.
Now I've got the engine sitting on an old tyre, all I have to do is clean it up a bit & then I'll be able to put it up for sale :) I was going to keep it for another car I was looking at buying that just needed a stronger engine, but the guy sold parts off it so I kept looking for one with most of the mods already, but picked up a series 2 33 last week that has pretty much everything done so now I don't have a use for it.
Just wanted to say thanks to Chris, Simon & TiTAN for your advice to help me out with doing this, thanks a lot guys :D For me it was a different experience for sure, but I can add that to the list of random things I have now done
Cheers :D
Nathan
https://www.sau.com.au/forums/topic/291165-removing-rb25/#findComment-4901000
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
