I have 2 questions
A friend owns a R31 Aus Skyline and it needs a brake up grade, I have heard lots but have not actually been told what does or what does not fit.
My understanding is GTR calieprs fit but only Jap R31 struts?
Any information would help.
my 2nd question in on R33 4spots, A friend has a pair he's giving me and the only thing is, I want to rebuild them, has anyone done tihs or know how much it costs for the kit, and the like.
Thanks RODHOG
https://www.sau.com.au/forums/topic/29117-brakes-question/
yes you need jap R31 struts - or custom caliper mounts to be made (which is expensive). When you put jap struts on you have many more options.
talk to a brake and clutch place for rebuild kits. 1 spot kits are cheap, 4 might be more costly. But make very sure you know what you're doing rebuilding brakes, if you don't have expertise on hand to supervise I'd let a workshop do it. Because if you stuff up one piston and it leaks, you squirt the fluid out your pedal goes to the floor and you have NO brakes. But rebuilding them is a very wise idea if their condition is unknown or suspect.
https://www.sau.com.au/forums/topic/29117-brakes-question/#findComment-597594
There are other dramas and costs if you try and use the australian struts/hubs. I did it. Not a good option. Costs a lot. Find some complete import struts if you want to do the upgrade. You also need r32 gtst master cyl, booster, some new hardlines made up, fluid, pads, engineering cert, wheels that will clear the callipers etc etc. Oh and if you upgrade the rears (custom job on an aussie 31) the package is awesome.
I recommend just getting slotted rotors, good pads and fluid for most people instead of putting on big units, unless you are really charging hard on the limit. In a value/cost/use sense that is, in theory everyone should get the biggest/best brakes they possibly can. Good pads and fluid means stuff that doesnt fade and usually costs a bit.
https://www.sau.com.au/forums/topic/29117-brakes-question/#findComment-598180
thanks Guys it really helps
At the moment the R31 is turbos and is makeing lost of power about 300Hp at the rear wheels and bit. Mate thinking of going the full Job but and Brembo calipers as he's getting another bottom Rb30 end made up to take more power then it's current light state of tune
After read a fair bit through your forums I didn't know the Jap model differed so much from the Aus built one's. Still love a GTS-R but
Thanks for the advice on the brakes, the last time I did rebuild calipers was on a Gemini when I was 15. Worked fine, After that I just left it to a pro. I think I will with these brakes as well.
Thanks for all the help too.
https://www.sau.com.au/forums/topic/29117-brakes-question/#findComment-598736
