Hmm there's alot of thoughts on oils.... I'm no expert but seems like redline is the go if you wanna spend the $ or fuchs. But i've never used either.
Just did an 8ok change and put motul 8100, which seemed to be a recommendation of a few different posts.
Put Nulon trans fluid in as well, but never used the nulon engine oil.
It's australian though, so that's a plus :rant:
Edited by bayslideblue
I'm looking at different oils to use for my car,
need some recommendations, I'm looking at this one NULON
http://www.nulon.com.au/products/Full_Synt...sel_Engine_Oil/
thoughts?
Cheers
I use Motul 300v Chrono (10w40) in the Stagea.
I used the that Nulon 10w40 that you are asking about in my wife's Magna kast service. Seems to be good shit.
the Magna was burning a heap of oil and was very noisy (probably due to the 3L of oil that was left in it after 10,000kms). Put the Nulon in with their tappet treatment, damn quiet now and is great on startup. My wife says that the car is much, much smoother now.
Have had in the Stagea (all 100% Synthetic);
Royal Purple - good.
SHell Helix Ultra - ok.
Mobil 1 5w40 - too thin, engine didn't "feel" together, was quite noisy and I didn't have the confidence to push it.
Castrol Edge - not so good. Engine "felt" loose and was a bit noisier than I would have liked.
Motul 8100 - rubbish, could smell it burning, when I changed it (800kms after putting it in) a large mass of crap that smelt like charcoal came out.
Amsoil 10w40 - good.
Penrite Syn 0w50- way too thick. Felt like the intake pipe was 90% blocked off. Just didn't want to rev. (changed after 1100kms)
Motul 300v Chrono 10w40 - Best to far... by a long way too! Engine revs effortlessly, is damn smooth and is quieter than the any on this list. (too bad it costs so much)
I used to change every 5000kms, but I have extended that to every 10,000kms with the 300v.
Will be trying the Nulon 10w40 with my next service (2000kms away).
I say give it a shot. If it doesn't feel good (you will know), just change it. 5L of Nulon is what, $50?
Oils have different grades. Have a read of the different grades of full synthetic oils. "Full synthetic" is sometimes more of a marketing term than actually 100% synthetic. It may or may not be true.
Basically if I remember correctly, Nulon 300V was one of the few grade 5 oils, most other full synthetics are grade 4 (redline & royal purple i think) which is still pretty good, and then there are also a lot of grade 3 oils, which are still listed as "full synthetic" even though some of them are actually a semi-synthetic. This includes shell helix ultra...unless they've changed it recently...
Either way a synthetic oil will work well, just depends how critical you are. The average joe just sends their car to your average mechanic and their cars usually last the distance...so who knows...
"I use Motul 300v Chrono (10w40) in the Stagea.
Castrol Edge - not so good. Engine "felt" loose and was a bit noisier than I would have liked."
What grade Castrol Edge were you using? I had been using 5w 30 which was no good for my car but now on 10w 60 it is fine.
It really depends on what sort of climate that you live in.
If you live in cold climates then look for a lower figure with the W after it (5W) means that the oil flows as a 5 weight oil at 0 degC.
If you live in higher temperatures obviously this is less important, so you can go to 10W or even 20W.
The higher number is how the oil perfoms (flows) at 100 degC. So a 5W/40 acts a 5 weight at 0 deg and a 40 weight at 100 deg.
Now obviously you'd like it to run as a 5 weight at 100 deg eh? WRONG.... 5 weight oil at 100 deg is like water! 40 weight oil at 0 deg is like honey. So that's why we want a 5W/40... which is pretty consistent all the way from 0 - 100 deg C.
Keeping an oil in your engine too long will load it with contaminates. Mainly carbon, but also some metals (your engine wear!!). The non-synthetic oils use polymers to boost the viscosity at higher temps.
Imagine them like bits of styrene packaging suspended in the oil. As it get hotter they expand and make the oil thicker. Your engine is mashing them up though all the time.
So eventually they lose the ability to expand and do their job properly. Which is why you need to change them fairly often.
Pure synthetics don't do this.
I used to work for a Shell company. Once Shell did an experiment on a Cummins diesel, they ran it to destruction. It took about 630,000 hours. They didn't change the oil, or filters. They worked out that the replacement cost outweighed the maintenance cost by a staggering $60,000!
I once did an oil test on Mobil 1, for a customer. After 20,000 km, the test came back "This oil is as new".
It did have some contaminants but this was minor. The oil itself had not degraded. Good filters are worth far more than this brand or that brand.
Me I use Castrol Edge 5W/30 at the moment. If money wasn't any object it would be Mobil 1 every time. I'd probably go to 10,000km oil changes then instead of about 5,000km which usually turn into 7,000km oil changes!!
Remember all oils are tested if you don't understand what you are putting in your engine..... go read!! Start by Google-ing Oil Viscosity Chart.
The better you understand the more confident you will be.....
Hope this helped though.
i have castrol edge 10w30 and i know what Cam means when he says it sounds 'loose' and yes its noisier then before!
that said, it revs more smoothly (to me) and hasnt discoloured the oil so it appears to be doing its job.
im also thinking of going down the nulon engine oil path soon
I currently use Martini Racing Oil
Synt http://www.martiniracing.com.au/resources/...tini%20Sint.pdf
Martini is my current aswell! although that WAS my first service just last week.
seems to be running fine if not slightly better than before!, and it had Motul in it before Martini i do beleive. ;)
Synforce ProSYN 730 - 7.5w/30
http://www.synforce.com.au/synthetics.html
Queensland made for nissan motors. Was in my car when i bought it and found it good, currently running Castrol edge 5w/30 and find it poor in comparison...
    • This has clearly gone off on quite a tangent but the suggestion was "go standalone because you probably aren't going to stop at just exhaust + a mild tune and manual boost controller", not "buy a standalone purely for a boost controller". If the scope does in fact stop creeping at an EBC then sure, buy an EVC7 or Profec or whatever else people like to run and stop there. And I have yet to see any kind of aftermarket boost control that is more complicated than a PID controller with some accounting for edge cases. Control system theory is an incredibly vast field yet somehow we always end up back at some variant of a PID controller, maybe with some work done to linearize things. I have done quite a lot, but I don't care to indulge in those pissing matches, hence posting primary sources. I deal with people quite frequently that scream and shout about how their opinion matters more because they've shipped more x or y, it doesn't change the reality of the data they're trying to disagree with. Arguing that the source material is wrong is an entirely separate point and while my experience obviously doesn't matter here I've rarely seen factory service manuals be incorrect about something. It's not some random poorly documented internal software tool that is constantly being patched to barely work. It's also not that hard to just read the Japanese and double check translations either. Especially in automotive parts most of it is loanwords anyways.
    • If you are keeping the current calipers you need to keep the current disc as the spacing of the caliper determines the disc diameter. Have you trial fitted the GTS brakes fit on a GTSt hub or is this forward planning? There could be differences in caliper mount spacing, backing plate and even hub shape that could cause an issue.
    • Hi there I have a r33 gts with 4 stud small brakes, I'm going to convert to 5 stud but keep the small brakes, what size rotor would I need?
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
