I drove a mates RB20DE Cefiro a while ago and it was gutless. As in worse than it should be (sorry, I think n/a RB20's only a single step up from a carby 202 in terms of power). I noted the cam angle sensor was in the full retard position. I thought this was sus so after the 'ear tune' method (holding it at 2000rpm and testing for best response) it ended up at full advance. I didn't like this either so I set it to about 75% and told him to run it on 98. The car ran a lot better but I really want to do the job properly...
So what connectors do I have to jump and what is the base timing? The rest of the car is dodgy so I have no reason to believe the CAS hasn't been removed and re-installed incorrectly (meaning that setting it at 3/4 of the slot may not actually be right on this car).
Thanks
Ben
https://www.sau.com.au/forums/topic/291203-rb20de-ignition-timing/
Ok I went to edit my previous statement and it let me start, then decided that I idn't have permission...
I would like to clarify my statement...
Sorry, I think n/a RB20's directly comparable to injected 202's in regards to power. Smoothness, response, economy, and torque spread they are f-a-r better at though (The RB...)
It's entirely possible that the three n/a RB20's I have driven were dudds though, as two of them were in cars of dubious heritage (as in they have been set upon by clueless boy racers, and it showed in the quality of their 'build').
the rb20de is gutless, there is no way around it. they will be beaten by any car with a NA sr20 because they put out similar power but are much lighter.
now to the timing issue, you really need to check the timing with a timing light. without that you may as well have just loosened it off, given it a flick and tightened it up where ever it stopped. the stock timing should be 15 degrees at idle. it is also ideal to put the car into base idle mode before adjusting the timing as this locks the timing to 15 degrees as it can vary by about 2 degrees at idle due to different loads such as the aircon being on, etc. not sure on the procedure for a rb20, but if i remember correctly with a sr20 you start the car, turn it off, unplug the tps and start the car again.
also the easiest and most accurate way to hook up the timing light is to get an old ignition lead and remove the coil from number 1 cylinder and plug in the lead to the coil and the spark plug. often they won't read correctly when hooking them up to other places.
if the timing is serverely out even with the CAS turned to either sxtreme, or it has to be turned to either extreme to get the correct timing, then i would guess that the timing belt has jumped a tooth.
    • Waaay ahead of ya....(evil laugh!!) Will show the fitment and spec details later when it isnt as rainy !
    • Thanks Dose.....    I appreciate it!!
    • I'll probably be putting the shit box back on the dyno again soon, I want to dial in the closed loop boost control properly. I'll have a camera facing the car/motor for fun too. Just note, there are essentially 3x 10AN inlets going into the catch can and 1x going back to the intake pipe. Most of the time the catch can "return" to the sump actually is the crank case breather, pushing air out.
    • I have the R3C with a Nismo slave and by no means does it behave like a stocker, it ain’t THAT bad. On take off just give a bit more throttle than you would say a coppermix and it’s fine. It will not slip though.
    • Okay. Final round of testing done. Got a friend to hook up a fancy scanner to the car and we also ran some compression and leakdown tests, she is healthy.  The MAF was definitely the culprit. So for future reference anyone with similar issues that find this thread. I suggest the following steps, in order of affordability:   Check your spark plugs for any fouling, replace plugs if they are bad or re adjust the gaps making it narrower (0.8mm would be good). Check every coil's resistance with a multimeter. It can be done by probing the IB and G pins on the coil pack. Resistance should be around 1.4 (+/- 0.1) Ohms Check the MAF. If you have Nissan connect or a good scanner with the 14 adapter it should allow you to see the voltage on the MAF reading should be around 1.1 - 1.2V when car is idling. But if you don't, buy a new MAF from Amazon and test, then return it. (For instance, I got a Chinese one for $40 that was reporting 1.3v on idle). If you still have scanner, you can run tests on the injectors to see if they are working, just remember to unplug the fuel pump fuse/relay and have no pressure on the line. Then listen for the noises that the injectors make. Clean/replace injectors as needed. Once you find the issue and fix, order thousands of dollars worth of OEM parts to refresh unrelated things (Optional)   PS: Thanks to the absolute legends of this forum for the responses and help to someone that went a bit over their head. (me)
