hey guys, we are selling off a few performance parts, that were going to be used, but have changed direction yet again... so up for grabs, is an assortment of japan's finest aftermarket parts (apart from the supertech springs which rival them) prices are all firm, if they seem unreasonable to you, we don't really want to hear about it... remember everything is new, apart from those which state that they are not...
only have some pics at the moment, will have all up over the weekend... located on the far north coast NSW, postage is available at an extra cost too.
rb26 apexi v-max camshafts 11.2mm lift, 260 duration $1200
rb26 apexi v-max lifters (these are needed with the cams due to the smaller base circle) (used for a short period of time with other apexi cams) $400
greddy fuel pressure gauge with all necessary wiring sensors etc (used in very good condition $250
greddy exhaust temp gauge, with all wiring and sensors (used in excellent condition) $250
rb26 tomei cam gears (only slightly used) $450
hks turbo timer (good condition, previously used, comes with r32 gtr loom adaptor) $80
rb26 supertech double valve springs and titanium retainers $750
post-56395-12550000353332_thumb.jpg , post-56395-1255001030006_thumb.jpg , post-56395-12550010709009_thumb.jpg
rb26 ferrea +1mm oversize valves (exhaust and intake) $650
post-56395-12550012169597_thumb.jpg , post-56395-12550012790052_thumb.jpg , post-56395-1255001387547_thumb.jpg , post-56395-12550014196299_thumb.jpg
rb26 ferrea collets (only have 24) $120
rb26 ferrea double valve spring seats (have 24) $120 (see above for pic)
greddy single turbo y-pipe (the one with 2 inlets and a return for a bov) (has also had extensive work inside to improve flow characteristics slightly) $320
hks supper dragger muffler (4in intake, 5in tip) absolutely beautiful muffler, has been used $450
rb26 polished Cam angle sensor (also have a polish cas mount to come with it) $250
rb26 polished camshaft covers, polished cam gear cover and polished coilpack cover $900
rb26 polished twin turbo pipe, has also been extensively worked inside too. $150
rb26 genuine nissan injector resistor pack $160
also forgot to mention, we will consider trading for items that we need, of equivalent value...
they include: power fc and hand controller, ati or ross harmonic balancer, lightweight over driven (pref greddy) pulley, rose jointed suspension arms for r32 gtr, sparco racing bucket seats (fixed back), hks exhaust cam (272 9.6mm), hks cam gears, tomei h-beam rods, arp head studs, acl bearings (or cosworth), dry sump set up, hks oil cooler, etc
if you have any of these, just let us know, and its condition (with pics of your actual item please)
we are yet to finalise our next set-up so let us know if you have anything different
cheers guys.
how many kms has the cas done
it came off a motor which had done 70,000k's mate, quite happy for you to test it before buying...
cheers
bump,
have a few more things for sale...
polished greddy (genuine) rb26 plenum... polished exterior, ported insides.... $1400 , these sell new for $1200+, and the polishing and porting cost alot...
ported injector assembly plate (the one that bolts between the head and tb's) $450
r33 v-spec turbo's with a genuine 17,000k's on them... $450
also have a standard rb26dett harmonic balancer in great condition, only removing to replace with an ati one... $200
will have some more pics up soon... some quicker upon request, and upon very genuine inquiries...
cheers
have an apexi powerfc w/ hand controller, still in box, never used, no tune on it. consider swap for tomei cam gears, ferrea double valves springs w/ retainers and the ferrea seats?
PM sent a while ago, and no reply??? please people if you are interested reply, if not don't bother. thanks
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
