Tcs Switch Not Working On R34 Gtt
Flecher
 Share
hi guys, my tcs switch doesn't work, when i press the switch it doesn't turn off the TCS.
I just got my car back from mechanic as my car couldn't start guess some sensor broke down. The mechanic rewire sth so it could start but then when i push the TCS button the TSC OFF light is not showing up on the dash. I wonder what's wrong with it.
Also, i got this TCS off , SLIP and Engine warning light on and the engine seem to crank and keep misfiring. But when i turn off the car and start again they gone again. I wonder what's the problem? Is sth wrong with the coilpack? as i feel the engine cranks so much n keep misfiring when those light on.
Need advise from everyone. THanks!
rewired what exactly? i cant think of anything needing re wiring to fix a break down on a 34. what was the cause of the breakdown...
because my mate's car got smashed at the front and cause has not spark to start up his car. When he turned on the car the engine just cranking and no spark to start it. Therefore the mechanic rewire sth to make it start. Perhaps i should get him to talk to mechanic.
  • 2 months later...
I do not think my TCS switch is working in my car either. Although mine hasn't had any rewiring done or anything. From reading this thread looks like there is a fuse so I'll go check all that now.
One question i have is how is the TCS Off switch meant to work do you just start the car and press the switch and then TCS off will come up on the display?
Also is the switch meant to be like a light switch wear you flick it and it stays there or like spring loaded kind of switch wear you press it and then it comes goes back to it's original position after pressing? Just asking as mine is like the spring loaded kind of switch
Edited by Marcus89
 Share
    • Installed  Nismo coppermix twin competition spec last year in my bnr32 with pull trans with Oem slave cylinder. The point at where the clutch disengages/enages is right at the top of the clutch pedal, meaning I barely have to push the pedal down for the clutch to be disengaged.  You guys that have the same combo are you experiencing this high pedal bite point??   Secondly I’d like to have the disengagement point lower meaning I have to push the pedal more(further not effort)for it to be disengaged.  I’m thinking to use a Nismo big operating cylinder(bigger bore at 13/16 vs Oem 3/4) which will require more pedal stroke to get the equivalent movement at the clutch fork. But I see Nismo web site says not to mix these 2 as the Nismo big operating cylinder doesn’t have enough stroke to disengage??? Any folks run both the coppermix twin pull with Nismo cylinder??    Thanks in advance for the replies but prefer only guys with pull clutches to respond. thanks
    • Any chance u could let us know where your based ?
    • That’s a great deal and I would jump on it if you were closer. Melbourne is a bit of a hike for me though unfortunately
    • I wonder if there is much to tell without knowing where the bolts where bought from. If it comes from Amazon or similar all bets are off. Can't trust them. And I fear not everybody knows that. Wasn't it @TurboTapin who ended up with the fake fuel lines recently? The submersible ones which very much weren't submersible at all. It kind of applies to everything nowadays. Doesn't matter if it's hardware or electronics. The fancy camera might have internals swapped out for cheap knockoffs. The hard drive will report a certain size but not actually be able to write it all. Shit like that. A bit depressing but the reality is you really have to be weary of where and how you buy stuff
