Hey im after some info on how to custom make fibreglass so that its fits my car.
Ill explain what my problem is,
I have an r32 and where the back seats are there is the covering around the window part there, seeing that its a 1992 its been in sun and that its fragile and sadly got mine with a broken trim. All the plastic in the top right of it (this is on my LHS) near the headrest of the passenger seat is all broken. so i was just wondering if theres a way do fibreglass round edges, i havent fibreglassed before but ill try till i get it right.
Any info on what to use etc would be great. Thanks jim.
https://www.sau.com.au/forums/topic/291275-fibreglassing-round-edges/
Can you put up a pic of what part you want to fix to give a better idea of what you're trynig to do?
If it is just really a cosmetic fix you're after you could just cover it in material, stretch old T-shirt etc and coat that in resin to make it hard. Sand back the peaks on it and then put a thin layer of bog on it and paint what ever colour you mant to. If youneed a bit more strength glass some light FG matting on before bogging. You're best to sand the plastic beforehand to roughen up the surface. Fiberglass doesn't really stick to plastics so it helps to make a little bit of a mechanical bond. If you want to make an even better mechanical bond b/w the fiberglass and plastic item you can also drill a few small holes in it and then loosly put some tape over the back of the holes. When you fiberglass on the front side it seeps through the holes and flows into the cavity left by the loose tape. This puts a 'flat' top on the end of it and it can't pull through so it holds it to the plastic.
If the plastic part needs to flex don't put anything on that's too thick otherwise it may not flex.
  • 1 month later...
    • Yeah. I believe the fear of annealing the alloy and weakening it, Every online discussion has someone saying it's bad and potentially a risk when powder coating forged wheels.
    • I'm interested if anyone agrees with what you've said, and can give a good reason. Temperature of powder coating should be below any temperature you'd use to alter the wheel structure.  Powder coat typically 200 to 250. Annealing if that's what people are claiming would be occuring, starts at 300, and depending on the alloy, can need even up at 400+.   That's the only part I can think of that could cause an issue that people are believing it's from the rim losing hardness and becoming too soft.
    • Negative probe should be on the cars chassis. Positive on the wire.   Start as said above by unplugging everything (unplug the lights, and switches. Now at the switch, there is a wire from the fuse, to the switch, so out your positive on that terminal. It should read open circuit. If it reads something, especially a stupid low value, the short is somewhere between the fuse and the switch. If that's fine, now put the positive probe on the wire that goes to the headlight (at the switch plug). If it reads stupid low, the fault is from the switch, to the headlight.   Another quick test, is take the whole LED light setup from the left, and plug it into the right side, does it still blow the fuse? If you put the right hand side led light setup on the left hand side wiring, does the left hand side wiring now blow?  If the blowing fuse swaps from right to left doing this, your LED lights are the issue.
    • Anyone know if it's a problem to powder coat forged alloy wheel centers (Rays/Volk GT-C). some say it's bad and can damage the alloy, some say it's not a problem.
