Just got the following parts put on:
-STRUP stainless headers
-Berk cats
-Ichiba y-pipe
-ztube and popcharger with heat shield
-motordyne spacer
-unorthodox racing pulleys with belts
-Stillen grounding kit
-06 jdm tailights
-NRG hood dampers
-B+M short shifter and Nismo carbon gearknob
-15mm Ichiba spacers front and 10mm rear
Wow what a difference these mods made! Car revs much quicker and the exhaust note is awesome. No rasp or drone yet.(has a kakimoto regu 06&r catback) Hopefully it stays that way.
All work was performed by Greg and the boys at autosport engineering and took 12 hours to do the lot including engine and gearbox oils. What a job they did and for an excellent price!!
The header install was not easy they tell me :P
Now off to get a tune on monday at CRD. Getting haltech platinum interceptor fitted.Hoping to pull high 180's or maybe even low 190's.
Will post dyno sheet up monday night
Edited by robbo33
https://www.sau.com.au/forums/topic/291277-parts-finally-on/
Yeah that's what i've read and what my bestmate experienced. He saw 20kw+ difference between CRD and ISMR. On another forum, some members have seen 15kw diff between CRD and UAS.
Doesn't really matter though..if it drives to your liking then it was worth it right :ermm:
I'll imagine after the tune, it should pull pretty sweetly! Let us know how it goes.
Doesn't really matter though..if it drives to your liking then it was worth it right :)
i might pull 200kw then :)
Nah thats fine i will get a before and after readout so i know how much extra power it made after the tune.....regardless of whether its a high figure or not. hoping for 10-15kw atw
we spend alot of money on our cars to extract little power
the $ - kw ratio imo is not worth it, hence why i will not be extensivley modifiying this car. not worth the money. rather make it look good than go good. no need for excessive speed on the street.
How'd it go Robbo33 ? :P
My tune only netted me peak 6kw atw i think, mid range was MUCH better though and no more gay 6600rpm rev limit now...feels like a totally different car. Oh and no more pinging whicich no doubt affected the power delivery (ECU constantly adjusting ignition etc).
No go yet!
the haltech got wired in and was all good to go. Put it on the dyno and it wouldnt rev past 5000rpm!
its a software error with haltech itself they said so back there on saturday to get it sorted out. all they need to do is make a phone call and it will be sorted instantly but because it was after 5pm they were closed.
Did pull 168rwkw without the tune though...so not to bad.
Full credit to the boys at CRD though as they were more devastated then me! they wanted me to leave the car there overnight so they could sort it first thing in the morning but i needed it for work tomorrow and to get home tonight (silverwater to miranda). they even offered me one of their cars for the night, but the tuner came in and said he just bypassed the haltech so it was running how it was when i drove it there.
So bring on saturday!
got the car back from crd today with dyno printout.
Made 179.6kw....couldnt quite get 180kw.
And the initial readout was 165.8kw not 168kw as they first told me.....so just under 15kw at the wheels with the tune and now revs to 7200rpm!
All in all im very impressed with how the car idles (before the tune the car would stall on cold starts and idle all over the shop) and the midrange is so much better.
will try and post dyno chart tomorrow
    • I'm seeing torque specs all over the place for the OUTER tie rod, but none for the INNER tie rod, where it connects to the steering rack. Even in videos, people are just tightening em up as much as they can with a wrench and that's it. Anything tightened down without torque makes me nervous. Anyone know what the spec is for it?
    • Hope you had a great time here in our tiny country.   The JDM scene we have here is quite small, it's mostly BMW, Volkswagen with burble tunes haha. But the few JDM cars we do have in the scene are pretty nice. Some of my friends drive cool s14's too. Both built engines, red one makes abt 500, blue one abt 400 i think?
    • Ye good idea , would have never thought of something like that. Might aswell do it to every pulley and the balancer while I’m there
    • Use an LS1 or similar, via kit like Frenchy's. But.... It's probably not the alternator. It sounds like belt squeal, which would be because the pulleys are glazed. Rub every groove on the pulleys with 120 grit paper. Report back. Oh, and new belts afterwards too. The old new ones will be shitted up already.
    • Hello all I have 2 r34 sedans , one turbo one na, only recently aquired the na 34.  Man what is with these things.... My turbo 34 started sounding like a super charger, it was screaming at anything above 4000rpm , I took the alternator apart and replaced the front bearing which is the only one I think you can access and it did not fix the issue so presumably the bearing in the rear of the alternator is gone. ( diagnosed it was the alternator by taking off the aux belts one by one to figure out which pulley or bearing it was )  My friend gave me one he had lying around, Installed it , it did not squeal for maybe 500kms and now its started to squeal again briefly on startup  Recently got an na r34 and I replaced the timing belt, water pump + all the auxillirary belts. Runs amazing but it suddenly developed the same squeaking problem but significantly worse, Ive had my neighbour come down screaming at me because it was waking her up everytime I moved the car. It takes a good 2 minutes before it quietens down.  Im yet to diagnose where its coming from but im fairly sure its coming from the alternator aswell. My question isnt about how to fix it but rather where can you get a new alternator for an rb25 neo??? Ive searched everywhere but I havent been able to find a direct fit oem type replacement thats not genuine. All the automotive stores sell an oex one - BXA035 - which I picked up for cheap through a friend with staff discount , got it home only to find the connector is completelty different.... As far as im aware bxa035 is for rb20/30's and after a bit of figuring out the bxa035 has an ev14 type connector, which is tiny compared to the rb25 connector. I actually had an ev14 connector lying around which I was considering just replacing the bigger plug with to get the alternator working but the bxa035 is rated for 70amp vs the rb25 alternators are 90amp ( or so ive been told ? ) That paired along with the fact im about to install an amp + sub in the back and I have the stock sized small battery Im not sure itll do the job unless anyone has another opinion?  I know and have seen all the websites selling the ls1 alternator conversion kit but I am not going down that route, nor do I have the money to. Hopefully I can figure out how to get 2 brand new alternators for both cars. I would buy second hand which there seems to be many of but considering how common this seems to be im sure If I installed a second hand one it would start squealing in no time  Or even better if anyone knows how to fix the issue directly with the alternator itself... Any input appreciated Thank you     Link for bxa035 connector picture
