My car is N/a at the moment and im doing a full conversion shortly, im buying/sorting everything out now.
what im doing is getting a rb25det engine putting into the gts r33, buying some mods and a power fc...
ill be taking by car to unique auto sports for a dyno tune but i wanted to know
do i have to change my wiring loom to the gtst setup before they install the power fc?
or do they add there own wiring harness to my N/a loom?
https://www.sau.com.au/forums/topic/291284-na-convert-gts-t-with-apexi-pfc/
wiring changes may be needed, the PFC assumes you have ECR33 RB25DET so whatever is different/missing on the loom the PFC wont know about
so check the wiring loom differences on RB25DE vs DET and make up what is missing. but the PFC is plug and play start first shot on a GTST
ok thanks mate, do u know where i could find the differences between the to?
and do u know somewhere i can find all the ecr33 power fc parts numbers, cause im about to pay for 1 and
i just want to make sure before i go ahead its the right 1,
the sticker reads " PFC ECR33 010- 1058"
this would work on a rb25det engine for an r33 wouldnt it?
yep the part # is correct
check my sig, the powerfc faq has everything you could ever possibly think of regarding the PFC
if its not in there, it either doesnt exist or no one cares bout it
part models and units are included in the faq
my site has the ECR33 wiring diagrams
from memory it shows you differecens between DE/DET
paulr33.skylinesaustralia.com
your site tell me this:
Second Generation is
###-XXXX
Where ### is the batch build number, so 000 or 010 or 020 (ie batch build 010)
XXXX is the unique item #
so in your opinion does that part number i showed u sound like the right thing?
