300rkw? yeah that turbo will get you 300, i'm not an expert on VQs, but i hear good things about them, have you consider a twin turbo setup?
nah, 300rwhp, to begin with, but after upgrades hoping for around 500ish rwhp,
does it matter that the turbo is suited for a diesel???
i have thought about twins but im trying to keep the build cost at a minimum, twins would be good coz of the v configuration, tho im happy with a big single :ermm:
https://www.sau.com.au/forums/topic/291287-turbo-advice/#findComment-4872670
  • 3 weeks later...
thats exaclty why im asking mate, i have been searching but getting mixed results with the gt4088r, my first response was it would be wayy to big...
and my next one was the precision pt67 as it is smaller, comparible to the 35r, but didnt know if it would run out of puff etc???
https://www.sau.com.au/forums/topic/291287-turbo-advice/#findComment-4912042
also should add i have been in a vl which had a gt4088r but slightly larger rear and it seemed pretty damn good, not the most responsive turbo tho not the most laggy either...
what would be perfect would be spool/boost characteristics for each, as when they would start and reach full etc
https://www.sau.com.au/forums/topic/291287-turbo-advice/#findComment-4912051
You been on one with a GT35?
I'll assume the answer is a no.
Select the turbo that fits your power goal, it's as simple as that. There is SOOOO much information in the pages of this forum about GT30/GT35/GT40 series turbos that you couldn't possibly be in the dark
https://www.sau.com.au/forums/topic/291287-turbo-advice/#findComment-4912106
