Is that an RB26 manifold though?
I had the same problem with a monster turbo i had a while back, but the reason it was so bad is that the manifold was an RB26 manifold and of course that doesnt account for the extra height
https://www.sau.com.au/forums/topic/291301-rb3026/#findComment-4909485
what surprises me stevo is the cam cover height in that pic, that bonnet is lower than factory
https://www.sau.com.au/forums/topic/291301-rb3026/#findComment-4909541
https://www.sau.com.au/forums/topic/291301-rb3026/#findComment-4909546
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
